10
Hey I just installed my 22.04 Ubuntu and the installation was successful. Unforetunately I seem to be stuck in a "Reset System" boot loop which I can't seem to get out of.
When I boot the OS from the USB it works fine. Also my previous OS was Ubuntu 18.04 and it didn't have this issues. Any suggestions as to what might be the problem ?
Svet
  • 105
9 Answers9
I had the same problem with my system. The problem is that it boots from /boot where it should boot from \EFI. You can test if this works by the method depicted by @Sudoanon. If this works you can define a customized boot option as follows.
  • Go into your bios
  • Go to boot options
  • Select add customized boot option
  • Define the path to be \EFI\ubuntu\grubx64.efi (or whatever works for you)
  • Set custom boot option as first priority in boot order.
  • Save and exit
This worked for me, I hope it works for you as well.
Evochrome
  • 236
I don't know why (probably because I use MBR partitions, NOT GPT!), but the grub-install in Ubuntu 22.04 installs the fbx64.efi into the /EFI/BOOT/ directory and during the boot the shim loader (in debug mode, activated via mokutil --set-verbosity true, I spent a while to debug this) shows Invoked from removable media path, ignoring boot optionsshim.c:912:load_image() attempting to load \EFI\Boot\fbx64.efi and immediately shows Reset System log. Removing a single \EFI\Boot\fbx64.efi file solves the Reset System issue. After the file removing the UEFI secure boot works just fine.
Hope this helps.
Details: MBR FS, Secure UEFI boot enabled, HP 2170p laptop
kay
  • 131
I found a quick solution at Reddit. There need to copy a file from EFI folder to BOOT folder like this:
cp /boot/efi/EFI/ubuntu/grub64.efi /boot/efi/EFI/Boot/bootx64.efi
It works for me.
deivan_
  • 131
I had this happen to my old HP laptop. I solved it temporarily by booting directly from the grub EFI file in BIOS but it still boot loops if I do not boot this way every single time.
UPD 2024: after upgrade Ubuntu 24.04 to 24.04.1 I got the same issue..
but my previous tip doesn't work, for that case you need to use next line:
cp /boot/efi/EFI/ubuntu/grubx64.efi /boot/efi/EFI/Boot/bootx64.efi
please note: not grub64.efi but grubx64.efi
Ivan D.
  • 29
I got Fedora and Windows 11 dualbooted on my HP laptop (it doesn't need to be dualbooted), pretty sure that this is the same for other systems so do this, it fixed the problem for me:
Reboot your laptop, press the key on your keyboard that can make you select which partition you want to boot into. (mine is F9, for others it's varying)
Then, select the drive on where you installed Ubuntu, select EFI, then select BOOT instead of ubuntu (or your distro name)
Then, boot into BOOTX64.efi (NOT bootx64.efi in the ubuntu folder), then it'll show a fullscreen prompt that says "Boot Option Restoration", then there will be a countdown on the bottom left screen.
Then, just wait for it to complete, then once you restart your computer the GRUB bootloader should appear, your computer will be usable again, and the Reset System screen should be gone! :D
2n32
On my HP Prodesk 800 this issue was resolved by disabling "fast boot" in the BIOS. Ubuntu immediately booted and continued to work as expected.
I ran into same problem on my HP PC. I was able to solved it with the following steps.
  1. Enter BIOS option
  2. In the Advanced tab, click Boot options
  3. Goto Boot Mode section to select UEFI Native (without CSM)
  4. Save settings and you are done
ganiular
  • 121
Had this on my Acer Aspire VN7-792G after reinstalling the system. Since I could not re-add the file (shimx64.efi in my case) for the attempt was rejected with “file is exist” I tried factory-resetting Secure Boot Config. I could add the file again afterwards and it worked.
I had to set a superuser password to alter secure boot settings, I could reset it to empty after doing my work.
karlsebal
  • 339
