Specs:
  • Ubuntu 24.04
  • Intel Core i7-10750H
  • 16GB RAM
  • SSD
Ubuntu, VSCode especially, is lagging. So far I've:
  • Checked the system monitor for processes with high memory usage and high and high CPU usage.
    CPU usage
  • Closed unused applications
  • Disabled unused startup applications
  • ran sudo apt-get update and sudo apt-get upgrade
The only recent change has been to install Evremap using a guide. However, Evremap isn't showing up in the system monitor or in Startup Applications despite running successfully.
What could the problem be?
karel
  • 122,292
  • 133
  • 301
  • 332
I had a similar problem with laggy and slow user interface, for example when watching videos, writing text in the search field of firefox, and also the mouse pointer was lagging a lot. The solution to your problem might be the same as for my problem. See this link about how I solved my problem.
Specifically, I did this:
Change in file /etc/default/grub the line GRUB_CMDLINE_LINUX_DEFAULT= quiet splash
to
GRUB_CMDLINE_LINUX_DEFAULT= quiet splash i915.tuxedo_disable_psr2=1 i915.enable_psr=0
Run sudo update-grub and then sudo reboot .
andrew.46
  • 39,359
