I'm using Ubuntu 24.04.1 LTS on an Intel Thinkpad. I have a weird problem since a couple of weeks where the new kernel (6.8.0-51-generic) doesn't boot. There's a kernel panic similar to this question.
The error message looks like (and the screen freezes):
VFS: Cannot open root device "/dev/nvme0n1pX" or unknown-block(0,0): error
Please append a correct "root=" boot option
Kernel Panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
I confirm that it is not a disk problem because I am able to use advanced options and boot using the older kernel. I tried the solution to that question which was to sudo update-initramfs -u -k version. Since some symptoms were superficially to this older question, whose solution also suggests update-initramfs -c -k , I tried it. But it has no effect.
When I use the older kernel (6.8.0-50-generic) and try dpkg --configure -a and apt upgrade, they both give this error:
Building module:
Cleaning build area...
make -j8 KERNELRELEASE=6.8.0-51-generic all KVERSION=...(bad exit status: 2)
ERROR (dkms apport): binary package for v4l2loopback_dc: 0.0.1 not found
Error! Bad return status for module build on kernel: 6.8.0-51-generic (x86_64)
Consult /var/lib/dkms/v4l2loopback_dc/0.0.1/build/make.log for more information.
dkms autoinstall on 6.8.0-51-generic/x86_64 succeeded for acpi-call
dkms autoinstall on 6.8.0-51-generic/x86_64 failed for v4l2loopback_dc(10)
Error! One or more modules failed to install during autoinstall.
Refer to previous errors for more information.
 * dkms: autoinstall for kernel 6.8.0-51-generic
   ...fail!
run-parts: /etc/kernel/postinst.d/dkms exited with return code 11
dpkg: error processing package linux-image-6.8.0-51-generic (--configure):
 installed linux-image-6.8.0-51-generic package post-installation script subprocess returned error exit status 11
 linux-headers-6.8.0-51-generic
The contents of the log file (/var/lib/dkms/v4l2loopback_dc/0.0.1/build/make.log) referenced above are:
DKMS make.log for v4l2loopback_dc-0.0.1 for kernel 6.8.0-51-generic (x86_64)
Saturday 04 January 2025 04:57:56 PM IST
make -C /lib/modules/6.8.0-51-generic/build M=/var/lib/dkms/v4l2loopback_dc/0.0.1/build modules
make[1]: Entering directory '/usr/src/linux-headers-6.8.0-51-generic'
warning: the compiler differs from the one used to build the kernel
  The kernel was built by: x86_64-linux-gnu-gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
  You are using:           gcc-13 (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0
  CC [M]  /var/lib/dkms/v4l2loopback_dc/0.0.1/build/v4l2loopback-dc.o
/var/lib/dkms/v4l2loopback_dc/0.0.1/build/v4l2loopback-dc.c: In function ‘vidioc_querycap’:
/var/lib/dkms/v4l2loopback_dc/0.0.1/build/v4l2loopback-dc.c:622:3: error: implicit declaration of function ‘strlcpy’; did you
mean ‘strscpy’? [-Werror=implicit-function-declaration]
  622 |   strlcpy(cap->driver, "Droidcam", sizeof(cap->driver));
      |   strscpy
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:243: /var/lib/dkms/v4l2loopback_dc/0.0.1/build/v4l2loopback-dc.o] Error 1
make[2]: *** [/usr/src/linux-headers-6.8.0-51-generic/Makefile:1925: /var/lib/dkms/v4l2loopback_dc/0.0.1/build] Error 2
make[1]: *** [Makefile:240: __sub-make] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-6.8.0-51-generic'
make: *** [Makefile:8: all] Error 2
Appreciate any guidelines on how to resolve it.
Edit - The output of dkms status is:
acpi-call/1.2.2, 6.8.0-50-generic, x86_64: installed
acpi-call/1.2.2, 6.8.0-51-generic, x86_64: installed
v4l2loopback_dc/0.0.1, 6.2.0-26-generic, x86_64: installed (WARNING! Diff between built and installed module!)
ahron
  • 261
This answer convinced me to not blindly remove the new kernel. So I tried to find another way. Although, this answer neatly lists the steps to follow to do just that.
After a good while, I solved it. I can only share how, I cannot fully explain the why of it.
  1. It was clear that the offending package which had a conflict was v4l2loopback_dc. This package is a dependency related to the droidcam app. Since I no longer use this app, I uninstalled it.
  2. Based on this answer I tried removing the v4l2loopback_dc but it somehow kept coming back. I tried reinstalling the correct version for the kernel but it didn't happen.
  3. This answer talks about the exact same problem, but with a different package. I followed the first few steps in that answer, as listed below:
  4. In the file, /usr/src/v4l2loopback_dc-0.0.1/dkms.conf, I changed AUTOINSTALL="yes" to AUTOINSTALL="no". This was the reason previous uninstall attempts weren't successful.
  5. Then I remove the module from the tree sudo dkms remove v4l2loopback_dc/0.0.1 -k --all
  6. Then I moved the folder away from /var/lib - sudo mv /var/lib/dkms/v4l2loopback_dc/ $HOME
  7. Finally, sudo apt -f install
  8. Now, it seems to be good :-) The system boots on the new kernel and apt seems act normal.
ahron
  • 261
