generic@motorbrot:~$ sudo dkms status
zfs, 0.8.4, 5.3.0-51-generic, x86_64: installed (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!)
zfs, 0.8.4, 5.3.0-53-generic, x86_64: installed (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!)
Why does this message appear?
I have tried removing and reinstalling zfs on one of these two kernels.
generic@motorbrot:~$ sudo dkms remove -m zfs -v 0.8.4 -k 5.3.0-53-generic
-------- Uninstall Beginning --------
Module: zfs
Version: 0.8.4
Kernel: 5.3.0-53-generic (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
zavl.ko:
- Uninstallation
- Deleting from: /lib/modules/5.3.0-53-generic/
rmdir: failed to remove '': No such file or directory
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
# [skipping long output that all looks similar but for different something.ko]
spl.ko:
- Uninstallation
- Deleting from: /lib/modules/5.3.0-53-generic/updates/dkms/
- Original module
depmod...
DKMS: uninstall completed.
generic@motorbrot:~$ sudo dkms install -m zfs -v 0.8.4 -k 5.3.0-53-generic
Kernel preparation unnecessary for this kernel. Skipping...
Running the pre_build script:
# [Skipping "checking for blah... blah" outputs]
Building module:
cleaning build area...
make -j8 KERNELRELEASE=5.3.0-53-generic............
Running the post_build script:
Signing module:
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/spl.ko
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/icp.ko
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/zfs.ko
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/zcommon.ko
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/zlua.ko
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/znvpair.ko
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/zunicode.ko
- /var/lib/dkms/zfs/0.8.4/5.3.0-53-generic/x86_64/module/zavl.ko
Secure Boot not enabled on this system.
DKMS: build completed.
zavl.ko:
Running module version sanity check.
Good news! Module version 0.8.4-1 for zavl.ko
exactly matches what is already found in kernel 5.3.0-53-generic.
DKMS will not replace this module.
You may override by specifying --force.
znvpair.ko:
- Original module
- Installation
- Installing to /lib/modules/5.3.0-53-generic/updates/dkms/
zunicode.ko:
Good news! Module version 0.8.4-1 for zunicode.ko
zcommon.ko:
- Original module
- Installation
zfs.ko:
- Original module
- Installation
icp.ko:
- Original module
- Installation
zlua.ko:
- Original module
- Installation
spl.ko:
- Original module
- Installation
depmod...
DKMS: install completed.
but the output of dkms status remains the same.
Why does this happen? Should I worry? And if I should worry, how would I go about fixing this?
