So I'm on Ubuntu 24.04 LTS and I'm having sound issues. I can hear my sound but it's got crackling and static in it. I hear this crackling and static in everything on my computer. My PC is about 10 years old I don't know if that has anything to do with it. It's got a modern SSD in it though.
So someone said "Apparently all sound issues are attributed to the 6.8 kernel, so downgrading to the previous version should fix it."
If this is true then how do I downgrade to the previous version? Is it safe if I do this, will it cause any problems?
Here's some basic info about my PC. Go ahead and tell me if you want me to enter in any other commands.
:~$ uname -a
Linux -System-Product-Name 6.8.0-51-generic #52-Ubuntu SMP PREEMPT_DYNAMIC Thu Dec 5 13:09:44 UTC 2024 x86_64 x86_64 x86_64 GNU/Linux
:~$ lspci -v | grep -A7 -i "audio"
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA)
Subsystem: ASUSTeK Computer Inc. M4A785TD Motherboard
Flags: bus master, slow devsel, latency 64, IRQ 16, NUMA node 0
Memory at fe8f4000 (64-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
01:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
Subsystem: Advanced Micro Devices, Inc. [AMD/ATI] Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
Flags: bus master, fast devsel, latency 0, IRQ 34, NUMA node 0
Memory at fe99c000 (64-bit, non-prefetchable) [size=16K]
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8192CE PCIe Wireless Network Adapter (rev 01)
:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: VT1708S Analog [VT1708S Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: SB [HDA ATI SB], device 3: VT1708S Digital [VT1708S Digital]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 9: HDMI 3 [55S421]
Subdevices: 0/1
card 1: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
:~$ pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 35
Server Protocol Version: 35
Is Local: yes
Client Index: 103
Tile Size: 65472
User Name: Joey
Host Name: Joey-System-Product-Name
Server Name: PulseAudio (on PipeWire 1.0.5)
Server Version: 15.0.0
Default Sample Specification: float32le 2ch 48000Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_01_00.1.hdmi-stereo-extra3
Default Source: alsa_output.pci-0000_00_14.2.hdmi-stereo.monitor
Cookie: e258:01c4
Yeah and I've already tried this and it didn't work at all How exactly do I edit /usr/share/pipewire/pipewire-pulse.conf?
I've tried a couple of other things as well trying to fix this. I haven't had sound in about 3 weeks now, is there any way I can fix this?
