I have followed the instructions mentioned here (same instructions are also mentioned here). Unfortunately, these instructions are catered to Ubuntu 20.04 and I am currently using Ubuntu 22.04. Here are the results:
- Instead of X11 (which was being used before this modification), Wayland is being used as the Windowing System.
- In the output of
nvidia-smi, one can see that a/usr/bin/gnome-shellprocess is being run on the GPU. (Note that the "NVIDIA On-Demand" PRIME Profile is in use)
Here is the nvidia-smi output:
| NVIDIA-SMI 550.120 Driver Version: 550.120 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap | Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4060 ... Off | 00000000:01:00.0 Off | N/A |
| N/A 30C P4 310W / 30W | 5MiB / 8188MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 1816 G /usr/bin/gnome-shell 2MiB |
Goal:
- Unless other programs that really need the dGPU (e.g. games or simulators utilizing Vulkan API, Deep Learning script that uses PyTorch) are being run, I want the dGPU to have no processes running on it.
nvidia-smistill works, the dGPU is still available for Deep Learning, heavy games, CUDA Debugging etc. (which isn't the case for rebooting aftersudo prime-select intel)
What further changes do I need to make? (willing to do a fresh install)
