I am curious how am I supposed to switch to using the nvidia card on my ubuntu 20.04 setup?
on 18.04 once installed, I could just plug in and go.. seems with 20.04 it is using both iGPU and PCI-E GPU... I see the device is here, I have nvidia-smi responding with output.. but the ubuntu gnome resolution is only going up to 1920x1080.. telling me it's using the intel iGPU off my core i7 2600K
Edit:
strangely, after reinstalling.. it now eroneously occupies the GPU even though I only get intel resolutions..
how do I revert so the iGPU is used 100% and the GPU is left freed ?
Erik
  • 288
This solution was given to me and tested via the NVIDIA linux forums
Essentially start the NVIDIA X Server settings:
https://forums.developer.nvidia.com/t/ubuntu-20-04-fresh-install-looking-for-how-to-use-prime-to-use-igpu-on-desktop-intel-gtx-1060/124195/2
under PRIME profiles select
NVIDIA OnDemand
next, you need to do the following :
  • add ‘nogpumanager’ kernel parameter
See https://wiki.ubuntu.com/Kernel/KernelBootParameters if you're unfamiliar with that step
  • delete /usr/share/X11/xorg.conf.d/11-nvidia-offload.conf
  • create /etc/X11/xorg.conf with contents:
   Section "Device"
       Identifier     "intel"
       Driver         "modesetting"
       BusID          "PCI:0:2:0"
   EndSection
Erik
  • 288
-1
Try changing the driver in Software & Updates --> Additional Drivers.
VidathD
  • 2,829
