I just installed Ubuntu. I originally had no sound but when I went to the sound settings, I found the option of 2 output devices: Speakers-Built-in Audio and Digital Output (S/PDIF) Built-in Audio.
When I select Speakers-Built-in Audio I have the option of 3 Configurations: Analog Stereo Output, Analog Surround 2.1 Output, and Analog Surround 4.0 output. I DO have sound when I use the two surround sound outputs however it is loud and one volume. The volume buttons do make the volume thing show up on display and the number goes up and down but no change until you get to 0 when it goes mute. The slider in the sound settings also does not do anything.
I did an LSPCI in terminal and here is what shows up.
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
00:03.0 Audio device: Intel Corporation Haswell-ULT HD Audio Controller (rev 09)
00:14.0 USB controller: Intel Corporation 8 Series USB xHCI HC (rev 04)
00:16.0 Communication controller: Intel Corporation 8 Series HECI #0 (rev 04)
00:1b.0 Audio device: Intel Corporation 8 Series HD Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 1 (rev e4)
00:1c.2 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 3 (rev e4)
00:1c.3 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 4 (rev e4)
00:1c.4 PCI bridge: Intel Corporation 8 Series PCI Express Root Port 5 (rev e4)
00:1f.0 ISA bridge: Intel Corporation 8 Series LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 8 Series SMBus Controller (rev 04)
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM4360 802.11ac Dual Band Wireless Network Adapter (rev 03)
03:00.0 Ethernet controller: Broadcom Inc. and subsidiaries NetXtreme BCM57766 Gigabit Ethernet PCIe (rev 01)
03:00.1 SD Host controller: Broadcom Inc. and subsidiaries BCM57765/57785 SDXC/MMC Card Reader (rev 01)
04:00.0 PCI bridge: Intel Corporation DSL4510 Thunderbolt Bridge [Redwood Ridge 4C 2013]
05:00.0 PCI bridge: Intel Corporation DSL4510 Thunderbolt Bridge [Redwood Ridge 4C 2013]
05:03.0 PCI bridge: Intel Corporation DSL4510 Thunderbolt Bridge [Redwood Ridge 4C 2013]
05:04.0 PCI bridge: Intel Corporation DSL4510 Thunderbolt Bridge [Redwood Ridge 4C 2013]
05:05.0 PCI bridge: Intel Corporation DSL4510 Thunderbolt Bridge [Redwood Ridge 4C 2013]
05:06.0 PCI bridge: Intel Corporation DSL4510 Thunderbolt Bridge [Redwood Ridge 4C 2013]
06:00.0 System peripheral: Intel Corporation DSL4510 Thunderbolt NHI [Redwood Ridge 4C 2013]
I have done some research and was in alsamixer whilst I was in linuxmint but I thought I messed everything up and decided I wanted to try ubuntu instead so just did a fresh install. The only thing I have modified was downloading a driver for the broadcom wifi to work.
Thank you for any help.
P.S. this Ubuntu 24.04.1 if that matters.
guiverc
  • 33,561
