I have solaar (1.1.13) showing the following information for a wireless touchpad, however the touchpad is ignored by the desktop environment (Wayland on Ubuntu 22.04).
It just stopped functioning a few days ago with no clear reason.
Wireless Touchpad
Device path : /dev/hidraw4
WPID : 4011
Codename : Wireless Touch
Kind : touchpad
Protocol : HID++ 2.0
Report Rate : 8ms
Serial number: DCBF0037
Model ID: 000000000000
Unit ID: 00000000
0: RQM 32.00.B0012
1: BL 02.00.B0001
2: 72
The power switch is located on the base.
Supports 20 HID++ 2.0 features:
0: ROOT {0000} V0
1: FEATURE SET {0001} V0
2: FEATURE INFO {0002} V0
3: DEVICE FW VERSION {0003} V0
Firmware: Firmware RQM 32.00.B0012 4011
Firmware: Bootloader BL 02.00.B0001 4011
Firmware: Hardware 72
Unit ID: 00000000 Model ID: 000000000000 Transport IDs: {}
4: DEVICE NAME {0005} V0
Kind: touchpad
5: BATTERY STATUS {1000} V0
Battery: 90%, discharging, next level 50%.
6: WIRELESS DEVICE STATUS {1D4B} V0
7: unknown:1DF3 {1DF3} V0 hidden
8: REPROG CONTROLS {1B00} V0
9: unknown:1F03 {1F03} V0 hidden
10: VERTICAL SCROLLING {2100} V0
Roller type: normal touch pad
Ratchet per turn: 18
Scroll lines: 0
11: HI RES SCROLLING {2120} V0
Hi-res scrolling disabled
Hi-res scrolling multiplier: 8
Scroll Wheel High Resolution (saved): True
Scroll Wheel High Resolution : False
12: MOUSE POINTER {2200} V0
DPI: 1000
Acceleration: low
Override OS ballistics
No vertical tuning, standard mice
13: DFUCONTROL LEGACY {00C0} V0
14: unknown:1E80 {1E80} V0 hidden
15: TOUCHPAD RAW XY {6100} V0 hidden
16: TOUCHPAD FW ITEMS {6010} V0
17: TOUCHPAD SW ITEMS {6011} V0
18: unknown:1E00 {1E00} V0 hidden
19: REPROG CONTROLS V2 {1B01} V0
Has 7 reprogrammable keys:
0: Application Switcher => Application Switcher mse
1: Left Button => Left Click mse, reprogrammable
2: Right Button => Right Click mse, reprogrammable
3: Back Button => Mouse Back Button mse
4: Forward Button => Mouse Forward Button mse
5: Show Desktop => Show Desktop mse
6: Analog HScroll => HorzScrollNoRepeatSet mse
I have had a similar issue few years ago, a few Ubuntu releases back, solved by upgrading. However I have this issue also with the latest version of solaar this time.
Of course I've already tried all the obvious things voodoo ― replacing batteries, restarting, re-pairing, using a different USB port ― several times.
What should be my next steps after the following?
diagnostic outputs from libinput:
$ libinput list-devices
Device: Logitech Wireless Touchpad
Kernel: /dev/input/event27
Group: 6
Seat: seat0, default
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: n/a
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: none
Disable-w-typing: n/a
Accel profiles: flat *adaptive
Rotation: n/a
Crucially, using sudo libinput debug-events I can see that every finger motion and every button click on the touchpad do accordingly translate to a POINTER_MOTION and POINTER_BUTTON event, same as when fiddling a plain mouse connected to the same machine. Only, the plain mouse moves the cursor and makes clicks happen, whereas with the touchpad there's no effect other than its events showing up in the wayland debug trace.
