I have been using Ubuntu for years, and most recently 24.04 without issues. After upgrading to 24.10, the Nvidia drivers seem to be disabled,and the "Additional Drivers" in "Software & Updates" is empty ("No additional drivers available").
The system appears to correctly detect the NVIDIA card:
─( sudo lshw -C display
*-display
description: VGA compatible controller
product: GK104 [GeForce GTX 770]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:02:00.0
logical name: /dev/fb0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list fb
configuration: depth=32 latency=0 resolution=1024,768
resources: memory:fa000000-faffffff memory:f0000000-f7ffffff memory:f8000000-f9ffffff ioport:e000(size=128) memory:c0000-dffff
and trying the autoinstall believes that everything is just fine:
└─( sudo ubuntu-drivers autoinstall
All the available drivers are already installed.
however, I am stuck with a 1024x768 low resolution, and I cannot change it in my System Settings Display pane.
I have also tried to install manually the NVIDIA drivers:
└─( sudo apt-get install nvidia-driver-550
and rebooted, but no success either.
I have had similar issues in the past (every new Ubuntu install practically requires the same dance) but the Additional Drivers have always been there.
Does anyone know how to make them appear again? Or at least configure it so that I can have back my high resolution display.
Thanks!
