My battery isnt shown, even in settings under power option any information of battery is missing. plus i am dealing with laptop not charging. for few second it get charged then goes off. I try to power on after unplugging charger but it wont turn on. So i quickly plug in charge while chargin indicator blinks and power on then it turn on but chargin indicator goes off and as soon as i plugged out charger laptop turns off.
user@user:~$ upower -i /org/freedesktop/UPower/devices/battery_BAT0
  native-path:          (null)
  power supply:         no
  updated:              Thu 01 Jan 1970 05:30:00 AM +0530 (1729919206 seconds ago)
  has history:          no
  has statistics:       no
  unknown
    warning-level:       unknown
    battery-level:       unknown
    percentage:          0% (should be ignored)
    icon-name:          '(null)'
rudy@rudy:~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 24.04.1 LTS Release: 24.04 Codename: noble
Sorry I put this as an answer because I can't comment yet
I suspect that the battery being dead, Ubuntu cannot show battery status.
The output you are getting is normally for OS running on Desktop, with no battery
However, as suggested in these answers, you may try :
  • Start power indicator service
$ /usr/lib/x86_64-linux-gnu/indicator-power/indicator-power-service &disown
  • Make sure it's installed (or trying to reinstall)
$ sudo apt-get install indicator-power
or
$ sudo apt-get purge indicator-power $ sudo apt-get install indicator-power
  • If you have gnome, you may try setting :
$ gsettings set org.gnome.settings-daemon.plugins.power active true
