I'm a complete novice in Ubuntu, although I have installed Ubuntu 20.04 on an old laptop which went straightforward, and don't know programming language either.(I just read threads and follow/copy the instructions) I recently replaced my laptop's (HP pavilion 17" Beatsaudio) RAM (from 6GB to 16GB) and put a new SSD hard disk in, because it was getting really slow, although everything functioned, including wifi. With a bootable usb-stick I installed Ubuntu 20.04. But since then I don't manage to make wifi working. I don't think I damaged anything while swapping RAM and SSD.
After searching I found and tried several solutions, but nothing worked. I also tried Ubuntu 20.04 but same result: no wifi found. Then I found what I believed the 'exact' problem that I have (because the person wrote about the identical 'broadcom device, including type' that I have. So just to be sure I didn't mess anything up in my previous attempts, I 'freshly reinstalled Ubuntu 24.04' and then followed this thread exactly.
https://github.com/Niels-van-den-Hork/ubuntu-wifi-broadcom-bcm43142-802.11b-g-n which led me to: Installing Broadcom Wireless Drivers (the steps in this last link I also saw in several youtube video's.) Unfortunately still no WIFI.....
Does anybody have a step by step explanation/solution for me? I can make printscreens of certain basics/info if necessary. Here's a few that I 'used' already during my search for a solution:
lspci -vnn | grep Network
08:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n [14e4:4365] (rev 01)
iwconfig lo no wireless extensions.
eno1 no wireless extensions.
udo apt install bcmwl-kernel-source Reading package lists... Done Building dependency tree... Done Reading state information... Done bcmwl-kernel-source is already the newest version (6.30.223.271+bdcom-23ubuntu1). 0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
UNDER THIS ONE THERE'S A LOT OF INFO, BUT THE PART REGARDING BROADCOM: lshw -pci:2 description: PCI bridge product: 8 Series PCI Express Root Port 3 vendor: Intel Corporation physical id: 1c.2 bus info: pci@0000:00:1c.2 version: e4 width: 32 bits clock: 33MHz capabilities: pci normal_decode bus_master cap_list configuration: driver=pcieport resources: irq:42 memory:b2500000-b25fffff -network UNCLAIMED description: Network controller product: BCM43142 802.11b/g/n vendor: Broadcom Inc. and subsidiaries physical id: 0 bus info: pci@0000:08:00.0 version: 01 width: 64 bits clock: 33MHz capabilities: cap_list configuration: latency=0 resources: memory:b2500000-b2507fff -pci:3 description: PCI bridge product: 8 Series PCI Express Root Port 4 vendor: Intel Corporation physical id: 1c.3 bus info: pci@0000:00:1c.3 version: e4 width: 32 bits clock: 33MHz capabilities: pci normal_decode bus_master cap_list configuration: driver=pcieport resources: irq:43 ioport:3000(size=4096) memory:b2400000-b24fffff -network description: Ethernet interface product: RTL810xE PCI Express Fast Ethernet controller vendor: Realtek Semiconductor Co., Ltd. physical id: 0 bus info: pci@0000:09:00.0 logical name: eno1 version: 08 serial: 6c:c2:17:63:40:3c size: 100Mbit/s capacity: 100Mbit/s width: 64 bits clock: 33MHz capabilities: bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
rfkill ID TYPE DEVICE SOFT HARD 0 bluetooth hci0 unblocked unblocked
mikewhatever
  • 33,013
