61
I occasionally update my kernel from this web site http://kernel.ubuntu.com/~kernel-ppa/mainline/
I have been always downloading 3 deb files for installing linux header all, linux image and linux headers. I noticed one more deb file recently for 64 bit kernel called Linux-image-extra.
I would like to know what does kernel file Linux-image-extra do and should I also install it?
Braiam
  • 69,112
This answer is obsolete for modern Ubuntu releases
Without the extra package, most hardware won't work!
It contains extra drivers left out of the base kernel package; install it only if you need these drivers
Sometimes, a specific variant of the linux-image is slimmed down by removing the less common kernel modules (drivers). In this case, the linux-image-extra package simply contains all of the "extra" kernel modules which were left out.
  • Officially, this only happens for the -virtual image; the most common hypervisors (Virtualbox, VMWare, Xen, KVM) emulate a well-defined and restricted set of hardware, so removing unnecessary drivers which increase the size of the kernel/initrd is a good idea. You can always get them back by installing the extras package.
  • The kernel team also appears to have adopted this method for some of the mainline-PPA -generic kernels; the reasoning and solution remain the same -- if it looks like the base kernel image is missing a module you need, install extras.
  • As far as I know, the above approach has not been taken for the Quantal kernels -- only -virtual is affected as usual.
ish
  • 141,990
18
In previous Ubuntu versions, the linux-image-extras was optional, tailored for virtual machines / servers.
As of Ubuntu 14.04, linux-image is a slim package (for virtual machines), and linux-image-extras now contains many drivers required for desktops.
In particular, usb-hid (keyboard support), is only present once you install the linux-image-extras package. A common mishap, which results in TTY1 hanging on boot, and unable to login using a keyboard.
Mainline kernels are shipped using a single linux-image package, such as linux-image-3.19.0-031900rc1-generic_3.19.0-031900rc1.201412210135_amd64.deb
Kevin
  • 1,031
