First time Ubuntu user and already having an issue! My ethernet is no longer working (showing *-network UNCLAIMED). Wonder if anybody can help. Outputs are as below.
sudo lshw - C net:
    *-network UNCLAIMED
    description: Ethernet controller
    product: Ethernet Connection (2) I219-V
    vendor: Intel Corporation
    physical id: 1f .6
    bus info: pci@0000:00:1f.6
    version: 31
    width: 32 bits
    clock: 33MHz
    capabilities: pm msi cap_list
    configuration: latency=0
    resources: memory:ef100000-ef11ffff
lspci -knn | grep Eth -A3; uname -a:
    00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I219-V [8086:15b8] (rev 31)
    Subsystem: Gigabyte Technology Co., Ltd Ethernet Connection (2) I219-V [1458:e000]
    Kernel modules: e1000e
    05:00.0 PCI bridge [0604]: Intel Corporation DSL6540 Thunderbolt [Alpine Ridge] [8086:1578]
    Kernel driver in use: pcieport
    Linux ubuntu 4.10.0-30-generic #34~16.04.1-Ubuntu SMP Wed Aug 2 02:13:56 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
dmesg | grep e100:
    [    0.834386] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
    [    0.835415] e1000e: Copyright(c) 1999 - 2015 Intel Corporation
    [    0.885478] e1000e: 0000:00:1f.6: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
    [    1.799124] e1000e: probe of 0000:00:1f.6 failed with error -2
sudo modprobe e1000e:
no output
To be honest, I'm not sure what else I could pull that would help. The device is also stand-alone which i'm sure doesn't help.
Thanks!
To just help you onto the next step in trying a newer kernel.
You can download the needed packages from multiple places and in multiple ways. One way you could get them is to download them from packages.ubuntu.com You will need this 3 packages for kernel 4.10.0-30-generic:
Pilot6
  • 92,041
Anders F. U. Kiær
  • 2,171
  • 18
  • 29
