How do I post to Gwibber from python?
I have tried
import gwibber.utils
foo = gwibber.utils.GwibberPublic()
foo.post("This is a test message")
from https://wiki.ubuntu.com/Quickly/Snippets.
But it doesn't work.
Eliah Kagan
  • 119,640
You should really be using the GIR based API, here is a more current example:
from gi.repository import Gwibber
s = Gwibber.Service ()
s.send_message ("This is the content to post", None, None, None)
That will post to all accounts that are currently enabled to send. Here are what the parameters for send_message are:
  send_message: Posts a message
  @message: The message to post to Gwibber as a string or None
  @id: The gwibber message id or None
  @action: The action or None (reply, private)
  @account_id: The ID of the account to post from or None
So if you want to only post from a specific account, you can do something like this:
accounts_service = Gwibber.Accounts.new ()
accts = accounts_service.list () # A list of Gwibber.Account objects
for acct in accts:
    print "Gwibber ID: %s, Service: %s, Username: %s, Send: %s" % (acct.props.id, acct.props.service, acct.props.username, "True" if acct.props.send_enabled == "1" else "False")
    #add code to check if this is the account you want to post from, like if you want to post from all twitter accounts you would do this
    if acct.props.service == "twitter":
        s.send_message ("Whatever you want to post", None, None, acct.props.id)
Ken VanDine
  • 1,195
