I upgraded to Ubuntu 24.04 a few weeks ago, but already like 1 week everything was running smoothly. And while I was doing some upgrades (mostly reinstalling CUDA, Nvidia driver, and some new conda envs, also playing around with the keyboard layout - Czech and Korean) the PC got stuck and nothing was working really - like no keyboard commands. I have turned off the PC and turned it on (just with the physical button). Now I am in this situation when it loads up to Login screen, I put my password and it breaks.
  1. Right after Login I get this screen. After entering the password
  2. Then after sometime it turns into this. So you can see that some apps are running (conky and the notes), but not normal Ubuntu screen. The error screen
What I have tried so far.
  1. From here: Ubuntu 24.04 doesn't load GUI and login screen after Upgrade from 23.10 I tried systemctl status gdm but I got this message Looks okay? so I guess this part is ok? Or not? Because I found here How to solve: gkr-pam: unable to locate daemon control file? that is is just informational message, not error.
  2. And from this Unable to login to Ubuntu 24.04 I have tried to change my password, but it didn't help either.
  3. I tried running dpkg -l | grep ^..r and dpkg-query -W -f='${db:Status-Abbrev} ${binary:Package}\n' | grep -E ^.[^nci] and dpkg -C to see if anything is broken, but it didn't show me anything... Also, sudo apt update + sudo apt upgrade run without showing any error.
  4. I tried running sudo apt install --reinstall ubuntu-desktop^ as suggested in the commentsAny error here? but I personally didn't see any error after the installation finished, so I tried to reboot the PC and still the same error.
Thank you for any advice!
Anya
So, this actually happened again to me on my other PC and I have figured out where was the problem, why the error happened and how to fix it.
Why did it happen
The error happened after installing sudo apt install fcitx-hangul because I wanted to get a proper Korean keyboard (taken advice from here).
How to fix it
So, I used these to uninstall fcitx-hangul:
  1. sudo apt purge fcitx-hangul
  2. sudo apt clean
  3. sudo apt autoremove
  4. reboot
How to add Korean keyboard
I have managed to add Korean keyboard through this guide
Anya
