I installed Ubuntu 24.04 LTS on LattePanda 3 Delta. In the beginning, I faced a strange problem - when I activated Desktop Sharing and after Remote Login, I couldn't back to Desktop Sharing. I tried it a few times with a fresh Ubuntu installation. However, the Remote Login function was pretty slow - I used Windows 11 to connect with the Ubuntu machine. For me it was not understandable because it's a native function of Ubuntu.
In the end, I have installed xRDP using this tutorial: https://c-nergy.be/blog/?p=19671
Now it works better but I am faced with a next problem. On a physical device, my Bluetooth works and everything works correctly. During the xRDP session, I don't have access to Bluetooth. In settings, I see the information: Plug in a dongle to use Bluetooth. I'm connecting to the Ubuntu machine as the same user (only one user has been added).
I checked Google and I found this post: Cannot unblock soft-blocked bluetooth
Bluetooth was locked by soft and I ran every command but without result.
In the end, I have installed Blueman using this solution: No Bluetooth Found. Plug in a dongle to use bluetooth
Finally, something has changed and I could connect headphones or a smartphone. I can send files from and to the Ubuntu machine using Bluetooth. But I can't for example change the output of sound. I have only xrdp and dummy output.
So my final questions are:
- Do I correctly set an XRDP connection using the tutorial above? Ubuntu solutions didn't work for me correctly.
- Has anybody faced the same issue with Bluetooth?
- I am connecting to user A locally. I'm connecting to user A via XRDP. Should I add this user to the audio and Bluetooth etc. group to use these functions remotely? How can I do this?
Thank you for every advice.
Best regards
