As many users, I'm having problems with the bluetooth. I'm using Linux 6.8.0-45-generic on x86_64 #45-Ubuntu 24.04.1 LTS, just freshly installed.
When I go on Settings -> Bluetooth and click the toggle to enable, it instantly disables itself.
My laptop is just bought and you can see the full specs here
I tried to follow most of the steps in
None solved the problem.
I cannot remove the battery from my laptop, so I tried the disable/enable on the bios trick but did not help.
The main error message reported is:
  • Bluetooth: hci0: Opcode 0x0c03 failed: -110
sudo dmesg | grep -i blue
[    2.511496] Bluetooth: Core ver 2.22
[    2.511532] NET: Registered PF_BLUETOOTH protocol family
[    2.511535] Bluetooth: HCI device and connection manager initialized
[    2.511548] Bluetooth: HCI socket layer initialized
[    2.511553] Bluetooth: L2CAP socket layer initialized
[    2.511561] Bluetooth: SCO socket layer initialized
[    4.437283] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.437291] Bluetooth: BNEP filters: protocol multicast
[    4.437307] Bluetooth: BNEP socket layer initialized
[    4.675379] Bluetooth: hci0: Opcode 0x0c03 failed: -110
But differently from many other people who reported the error, when I check the status of bluetooth.service it says active:
sudo systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
     Active: active (running) since Tue 2024-09-17 13:17:46 BST; 21min ago
       Docs: man:bluetoothd(8)
   Main PID: 949 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 37564)
     Memory: 2.8M (peak: 3.1M)
        CPU: 51ms
     CGroup: /system.slice/bluetooth.service
             └─949 /usr/libexec/bluetooth/bluetoothd
Sep 17 13:17:46 matrix bluetoothd[949]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled Sep 17 13:17:46 matrix bluetoothd[949]: src/plugin.c:plugin_init() System does not support micp plugin Sep 17 13:17:46 matrix bluetoothd[949]: src/plugin.c:plugin_init() System does not support vcp plugin Sep 17 13:17:46 matrix bluetoothd[949]: src/plugin.c:plugin_init() System does not support mcp plugin Sep 17 13:17:46 matrix bluetoothd[949]: src/plugin.c:plugin_init() System does not support bass plugin Sep 17 13:17:46 matrix bluetoothd[949]: src/plugin.c:plugin_init() System does not support bap plugin Sep 17 13:17:46 matrix bluetoothd[949]: Bluetooth management interface 1.22 initialized Sep 17 13:17:46 matrix systemd[1]: Starting bluetooth.service - Bluetooth service... Sep 17 13:17:46 matrix (uetoothd)[949]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (> Sep 17 13:17:46 matrix systemd[1]: Started bluetooth.service - Bluetooth service.
Does anyone have any tips of what could I try/check?
Edited: Adding lsusb output as requested.
$ lsusb; sudo dmesg| grep -i firm
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. Hub
Bus 001 Device 003: ID 13d3:3585 IMC Networks Wireless_Device
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 05e3:0620 Genesys Logic, Inc. GL3523 Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 2b7e:c858 Kingcome FHD WebCam
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
It's an internal blutooth not a usb one... but added in case I'm missing something.
daemon_nio
  • 53
That device isn't in the kernel source code yet, in terminal check mokutil --sb as Secure Boot needs to be disabled, then
sudo apt install git dkms
git clone https://github.com/jeremyb31/bluetooth-6.8.git
sudo dkms add ./bluetooth-6.8
sudo dkms install btusb/4.1
Reboot
Jeremy31
  • 13,293
