I use my NVIDIA GPU's sound output as main sound sink. However, from time to time, I plug in an EPOS headset (a USB dongle that wirelessly communicates to the actual headset).
Under KUbuntu 22.04, pulseaudio would automatically switch to EPOS for sound input and output.
Sinc upgrading to KUbuntu 24.04.1, this has not been working as well, and I am at a loss to debug it because I am not familiar with pipewire nor with the pipewire-pulse "bridge".
Upon plugging in the EPOS dongle, the switch does not happen correctly : in pavucontrol, EPOS is shown as the default source and sink, but there is no actual sound. I can get it to work by using pavucontrol to select NVIDIA GPU as the default, then again EPOS.
On some occasion (during a webconference), I suddenly got no more sound. I restored it by doing the same manoeuvre in pavucontrol. But it went awry again when I closed pavucontrol. This however does not happen systematically but seems random.
My configuration is, I think, pretty standard for an upgrade from 22.04 to 24.04. The only change I made is I created a symlink to /bin/true under $HOME/bin/pulseaudio : this enabled a game (Victoria 3) to correctly detect the NVIDIA GPU sound sink (it would output to the computer case's internal speaker otherwise).
FYI, the webconference was with Big Blue Button under Firefox (obtained from Mozilla directly, not the snap distrib).
Here is the beginning of the output of pactl list while the EPOS dongle is working (is there an equivalent for pipewire ?) :
Module #1
Nom : libpipewire-module-rt
Paramètre : {
nice.level = -11
rt.prio = 88
#rt.time.soft = -1
#rt.time.hard = -1
#uclamp.min = 0
#uclamp.max = 1024
Nombre d’utilisations : n/d
Propriétés :
module.name = "libpipewire-module-rt"
object.id = "1"
object.serial = "1"
module.author = "Wim Taymans <wim.taymans@gmail.com>"
module.description = "Use realtime thread scheduling, falling back to RTKit"
module.usage = "( nice.level=<priority: default 20(don't change)> ) ( rt.prio=<priority: default 83> ) ( rt.time.soft=<in usec: default -1> ) ( rt.time.hard=<in usec: default -1> ) ( rlimits.enabled=<default true> ) ( rtportal.enabled=<default true> ) ( rtkit.enabled=<default true> ) ( uclamp.min=<default 0> ) ( uclamp.max=<default 1024> )"
module.version = "1.0.5"
nice.level = "-11"
rt.prio = "88"
Module #2
Nom : libpipewire-module-protocol-native
Paramètre : {
# List of server Unix sockets, and optionally permissions
#sockets = [ { name = "pipewire-0" }, { name = "pipewire-0-manager" } ]
Propriétés :
module.name = "libpipewire-module-protocol-native"
object.id = "2"
object.serial = "2"
module.description = "Native protocol using unix sockets"
Module #3
Nom : libpipewire-module-profiler
Paramètre :
Propriétés :
module.name = "libpipewire-module-profiler"
object.id = "3"
object.serial = "3"
module.description = "Generate Profiling data"
Module #5
Nom : libpipewire-module-metadata
Paramètre :
Propriétés :
module.name = "libpipewire-module-metadata"
object.id = "5"
object.serial = "5"
module.description = "Allow clients to create metadata store"
Module #7
Nom : libpipewire-module-spa-device-factory
Paramètre :
Propriétés :
module.name = "libpipewire-module-spa-device-factory"
object.id = "7"
object.serial = "7"
module.description = "Provide a factory to make SPA devices"
Module #9
Nom : libpipewire-module-spa-node-factory
Paramètre :
Propriétés :
module.name = "libpipewire-module-spa-node-factory"
object.id = "9"
object.serial = "9"
module.description = "Provide a factory to make SPA nodes"
Module #11
Nom : libpipewire-module-client-node
Paramètre :
Propriétés :
module.name = "libpipewire-module-client-node"
object.id = "11"
object.serial = "11"
module.description = "Allow clients to create and control remote nodes"
Module #13
Nom : libpipewire-module-client-device
Paramètre :
Propriétés :
module.name = "libpipewire-module-client-device"
object.id = "13"
object.serial = "13"
module.description = "Allow clients to create and control remote devices"
Module #15
Nom : libpipewire-module-portal
Paramètre :
Propriétés :
module.name = "libpipewire-module-portal"
object.id = "15"
object.serial = "15"
Module #16
Nom : libpipewire-module-access
Paramètre : {
# Socket-specific access permissions
#access.socket = { pipewire-0 = "default", pipewire-0-manager = "unrestricted" }
# Deprecated legacy mode (not socket-based),
# for now enabled by default if access.socket is not specified
#access.legacy = true
Propriétés :
module.name = "libpipewire-module-access"
object.id = "16"
object.serial = "16"
module.description = "Perform access check"
module.usage = "( access.socket={ <socket>=<access>, ... } ) ( access.legacy=true ) "
Module #17
Nom : libpipewire-module-adapter
Paramètre :
Propriétés :
module.name = "libpipewire-module-adapter"
object.id = "17"
object.serial = "17"
module.description = "Manage adapter nodes"
Module #19
Nom : libpipewire-module-link-factory
Paramètre :
Propriétés :
module.name = "libpipewire-module-link-factory"
object.id = "19"
object.serial = "19"
module.description = "Allow clients to create links"
module.usage = "( allow.link.passive=<bool, default false> ) "
Module #21
Nom : libpipewire-module-session-manager
Paramètre :
Propriétés :
module.name = "libpipewire-module-session-manager"
object.id = "21"
object.serial = "21"
module.author = "George Kiagiadakis <george.kiagiadakis@collabora.com>"
module.description = "Implements objects for session management"
Module #28
Nom : libpipewire-module-jackdbus-detect
Paramètre : {
#jack.library = libjack.so.0
#jack.server = null
#jack.client-name = PipeWire
#jack.connect = true
#tunnel.mode = duplex # source|sink|duplex
source.props = {
#audio.channels = 2
#midi.ports = 1
#audio.position = [ FL FR ]
# extra sink properties
sink.props = {
#audio.channels = 2
#midi.ports = 1
Propriétés :
module.name = "libpipewire-module-jackdbus-detect"
object.id = "28"
object.serial = "28"
Module #536870912
Nom : module-always-sink
Paramètre :
Propriétés :
module.author = "Pauli Virtanen <pav@iki.fi>"
module.description = "Always keeps at least one sink loaded even if it's a null one"
module.usage = "sink_name=<name of sink>"
Destination #126
État : IDLE
Nom : alsa_output.pci-0000_01_00.1.hdmi-stereo
Description : HDA NVidia Digital Stereo (HDMI)
Pilote : PipeWire
Spécification de l’échantillon : s32le 2ch 48000Hz
Plan des canaux : front-left,front-right
Module du propriétaire : 4294967295
Sourdine : non
Volume : front-left: 29491 / 45% / -20,81 dB, front-right: 29491 / 45% / -20,81 dB
balance 0,00
Volume de base : 65536 / 100% / 0,00 dB
Source du moniteur : alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor
Latence : 0 usec, configuré 0 usec
Marqueurs : HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Propriétés :
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.class = "generic"
alsa.components = "HDA:10de0094,14628d92,00100100"
alsa.device = "3"
alsa.driver_name = "snd_hda_intel"
alsa.id = "NVidia"
alsa.long_card_name = "HDA NVidia at 0xef080000 irq 17"
alsa.mixer_name = "Nvidia GPU 94 HDMI/DP"
alsa.name = "DELL U2718Q"
alsa.resolution_bits = "16"
alsa.subclass = "generic-mix"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
api.alsa.card.longname = "HDA NVidia at 0xef080000 irq 17"
api.alsa.card.name = "HDA NVidia"
api.alsa.path = "hdmi:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
card.profile.device = "4"
device.api = "alsa"
device.class = "sound"
device.id = "48"
device.profile.description = "Digital Stereo (HDMI)"
device.profile.name = "hdmi-stereo"
device.routes = "1"
factory.name = "api.alsa.pcm.sink"
media.class = "Audio/Sink"
device.description = "HDA NVidia"
node.name = "alsa_output.pci-0000_01_00.1.hdmi-stereo"
node.nick = "DELL U2718Q"
node.pause-on-idle = "false"
object.path = "alsa:pcm:0:hdmi:0:playback"
priority.driver = "696"
priority.session = "696"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "35"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "79"
object.serial = "126"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "0"
api.acp.auto-port = "false"
api.acp.auto-profile = "false"
api.alsa.card = "0"
api.alsa.use-acp = "true"
api.dbus.ReserveDevice1 = "Audio0"
device.bus = "pci"
device.bus_path = "pci-0000:01:00.1"
device.enum.api = "udev"
device.icon_name = "audio-card-analog-pci"
device.name = "alsa_card.pci-0000_01_00.1"
device.nick = "HDA NVidia"
device.plugged.usec = "7069916"
device.product.id = "0x10fa"
device.subsystem = "sound"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card0"
device.vendor.id = "0x10de"
device.vendor.name = "NVIDIA Corporation"
device.string = "0"
Ports :
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
Port actif : hdmi-output-0
Formats :
pcm
Destination #146
État : RUNNING
Nom : alsa_output.usb-EPOS_EPOS_BTD_800_A000870205107583-00.analog-stereo
Description : EPOS BTD 800 Analog Stereo
Pilote : PipeWire
Spécification de l’échantillon : s16le 2ch 48000Hz
Sourdine : non
Volume : front-left: 26214 / 40% / -23,88 dB, front-right: 26214 / 40% / -23,88 dB
balance 0,00
Volume de base : 41335 / 63% / -12,01 dB
Source du moniteur : alsa_output.usb-EPOS_EPOS_BTD_800_A000870205107583-00.analog-stereo.monitor
Marqueurs : HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Propriétés :
alsa.card = "3"
alsa.card_name = "EPOS BTD 800"
alsa.components = "USB1395:0382"
alsa.device = "0"
alsa.driver_name = "snd_usb_audio"
alsa.id = "E800"
alsa.long_card_name = "EPOS EPOS BTD 800 at usb-0000:00:14.0-2, full speed"
alsa.mixer_name = "USB Mixer"
alsa.name = "USB Audio"
api.alsa.card.longname = "EPOS EPOS BTD 800 at usb-0000:00:14.0-2, full speed"
api.alsa.card.name = "EPOS BTD 800"
api.alsa.path = "front:3"
api.alsa.pcm.card = "3"
card.profile.device = "3"
device.api = "alsa"
device.id = "84"
device.profile.description = "Analog Stereo"
device.profile.name = "analog-stereo"
device.routes = "1"
device.description = "EPOS BTD 800"
node.name = "alsa_output.usb-EPOS_EPOS_BTD_800_A000870205107583-00.analog-stereo"
node.nick = "EPOS BTD 800"
object.path = "alsa:pcm:3:front:3:playback"
priority.driver = "1009"
priority.session = "1009"
factory.id = "18"
client.id = "35"
object.id = "86"
object.serial = "146"
api.alsa.period-size = "256"
api.alsa.period-num = "128"
api.alsa.headroom = "256"
api.alsa.card = "3"
api.dbus.ReserveDevice1 = "Audio3"
device.bus = "usb"
device.bus-id = "usb-EPOS_EPOS_BTD_800_A000870205107583-00"
device.bus_path = "pci-0000:00:14.0-usb-0:2:1.0"
device.icon_name = "audio-card-analog-usb"
device.name = "alsa_card.usb-EPOS_EPOS_BTD_800_A000870205107583-00"
device.nick = "EPOS BTD 800"
device.plugged.usec = "2794502964"
device.product.id = "0x0382"
device.product.name = "EPOS BTD 800"
device.serial = "EPOS_EPOS_BTD_800_A000870205107583"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/sound/card3"
device.vendor.id = "0x1395"
device.vendor.name = "DSEA A/S"
device.string = "3"
Ports :
analog-output: Analog Output (type: Analog, priority: 9900, availability unknown)
Port actif : analog-output
Formats :
pcm
Source #62
État : RUNNING
Nom : alsa_input.usb-046d_0809_78AC8FE2-02.mono-fallback
Description : Webcam Pro 9000 Mono
Pilote : PipeWire
Spécification de l’échantillon : s16le 1ch 48000Hz
Plan des canaux : mono
Sourdine : non
Volume : mono: 65536 / 100% / 0,00 dB
balance 0,00
Volume de base : 19944 / 30% / -31,00 dB
Moniteur de la destination : n/d
Marqueurs : HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Propriétés :
alsa.card = "1"
alsa.card_name = "USB Device 0x46d:0x809"
alsa.components = "USB046d:0809"
alsa.device = "0"
alsa.id = "U0x46d0x809"
alsa.long_card_name = "USB Device 0x46d:0x809 at usb-0000:00:14.0-5, high speed"
api.alsa.card.longname = "USB Device 0x46d:0x809 at usb-0000:00:14.0-5, high speed"
api.alsa.card.name = "USB Device 0x46d:0x809"
api.alsa.path = "hw:1"
api.alsa.pcm.card = "1"
api.alsa.pcm.stream = "capture"
audio.channels = "1"
audio.position = "MONO"
card.profile.device = "1"
device.api = "alsa"
device.id = "49"
device.profile.description = "Mono"
device.profile.name = "mono-fallback"
device.routes = "1"
factory.name = "api.alsa.pcm.source"
media.class = "Audio/Source"
device.description = "Webcam Pro 9000"
node.name = "alsa_input.usb-046d_0809_78AC8FE2-02.mono-fallback"
node.nick = "USB Device 0x46d 0x809"
object.path = "alsa:pcm:1:hw:1:capture"
priority.driver = "2000"
priority.session = "2000"
factory.id = "18"
client.id = "35"
factory.mode = "split"
object.id = "62"
object.serial = "62"
api.alsa.period-size = "512"
api.alsa.period-num = "64"
api.alsa.headroom = "512"
api.alsa.card = "1"
api.dbus.ReserveDevice1 = "Audio1"
device.bus = "usb"
device.bus-id = "usb-046d_0809_78AC8FE2-02"
device.bus_path = "pci-0000:00:14.0-usb-0:5:1.2"
device.form_factor = "webcam"
device.icon_name = "camera-web-analog-usb"
device.name = "alsa_card.usb-046d_0809_78AC8FE2-02"
device.nick = "USB Device 0x46d:0x809"
device.plugged.usec = "7635131"
device.product.id = "0x0809"
device.product.name = "Webcam Pro 9000"
device.serial = "046d_0809_78AC8FE2"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.2/sound/card1"
device.vendor.id = "0x046d"
device.vendor.name = "Logitech, Inc."
device.string = "1"
Ports :
analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
Port actif : analog-input-mic
Formats :
pcm
Source #126
État : IDLE
Nom : alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor
Description : Monitor of HDA NVidia Digital Stereo (HDMI)
Pilote : PipeWire
Sourdine : non
Volume : front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
Moniteur de la destination : alsa_output.pci-0000_01_00.1.hdmi-stereo
Propriétés :
alsa.card = "0"
alsa.device = "3"
alsa.id = "NVidia"
device.api = "alsa"
device.class = "monitor"
device.id = "48"
device.routes = "1"
factory.id = "18"
client.id = "35"
object.id = "79"
api.alsa.card = "0"
device.bus = "pci"
device.string = "0"
Ports :
Formats :
pcm
Source #146
État : RUNNING
Nom : alsa_output.usb-EPOS_EPOS_BTD_800_A000870205107583-00.analog-stereo.monitor
Description : Monitor of EPOS BTD 800 Analog Stereo
Pilote : PipeWire
Sourdine : non
balance 0,00
Moniteur de la destination : alsa_output.usb-EPOS_EPOS_BTD_800_A000870205107583-00.analog-stereo
Propriétés :
alsa.card = "3"
alsa.device = "0"
alsa.id = "E800"
device.api = "alsa"
device.id = "84"
device.routes = "1"
factory.id = "18"
client.id = "35"
object.id = "86"
api.alsa.card = "3"
device.bus = "usb"
device.string = "3"
Ports :
Formats :
pcm
Source #147
État : RUNNING
Nom : alsa_input.usb-EPOS_EPOS_BTD_800_A000870205107583-00.mono-fallback
Description : EPOS BTD 800 Mono
Pilote : PipeWire
Spécification de l’échantillon : s16le 1ch 16000Hz
Sourdine : non
balance 0,00
Propriétés :
alsa.card = "3"
alsa.device = "0"
alsa.id = "E800"
api.alsa.path = "hw:3"
card.profile.device = "2"
device.api = "alsa"
device.id = "84"
device.routes = "1"
node.name = "alsa_input.usb-EPOS_EPOS_BTD_800_A000870205107583-00.mono-fallback"
object.path = "alsa:pcm:3:hw:3:capture"
factory.id = "18"
client.id = "35"
object.id = "88"
object.serial = "147"
node.max-latency = "16000/16000"
api.alsa.period-num = "125"
api.alsa.card = "3"
device.bus = "usb"
device.string = "3"
Ports :
analog-input-headset-mic: Headset Microphone (type: Casque, priority: 8800, availability unknown)
Port actif : analog-input-headset-mic
Formats :
pcm
