I am using ubuntu 24.04 LTS . I am using kernal version 6.8.0-39-generic I am running 64bit x86 architecture.
first when i run this code i am getting error of unmet dependencies:
user@omkar:~$ sudo apt upgrade
[sudo] password for user:
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
wpasupplicant : Depends: libc6 (>= 2.34) but it is not installed
Depends: libdbus-1-3 (>= 1.9.14) but it is not installed
Depends: libnl-3-200 (>= 3.2.21) but it is not installed
Depends: libnl-genl-3-200 (>= 3.2.7) but it is not installed
Depends: libnl-route-3-200 (>= 3.4.0) but it is not installed
Depends: libpcsclite1 (>= 1.0.0) but it is not installed
Depends: libreadline8t64 (>= 6.0) but it is not installed
Depends: libssl3t64 (>= 3.0.0) but it is not installed
Depends: adduser but it is not installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
so after i tried sudo apt --fix-broken install , and again i got new error :
user@omkar:~$ sudo apt --fix-broken install Reading package lists... Done Building dependency tree... Done Reading state information... Done Correcting dependencies... Done The following additional packages will be installed: adduser apt apt-utils ca-certificates dbus dbus-bin dbus-daemon dbus-session-bus-common dbus-system-bus-common debconf debconf-i18n dpkg gcc-14-base gpgv libacl1 libapparmor1 libapt-pkg6.0t64 libassuan0 libaudit-common libaudit1 libbz2-1.0 libc6 libcap-ng0 libcap2 libcrypt1 libdb5.3t64 libdbus-1-3 libexpat1 libffi8 libgcc-s1 libgcrypt20 libgmp10 libgnutls30t64 libgpg-error-l10n libgpg-error0 libhogweed6t64 libidn2-0 liblocale-gettext-perl liblz4-1 liblzma5 libmd0 libnettle8t64 libnl-3-200 libnl-genl-3-200 libnl-route-3-200 libnpth0t64 libp11-kit0 libpam-modules libpam-modules-bin libpam0g libpcre2-8-0 libpcsclite1 libreadline8t64 libseccomp2 libselinux1 libsemanage-common libsemanage2 libsepol2 libssl3t64 libstdc++6 libsystemd0 libtasn1-6 libtext-charwidth-perl libtext-iconv-perl libtext-wrapi18n-perl libtinfo6 libudev1 libunistring5 libxxhash0 libzstd1 openssl passwd perl-base readline-common sensible-utils tar ubuntu-keyring zlib1g Suggested packages: perl cron quota ecryptfs-utils apt-doc aptitude | synaptic | wajig dpkg-dev gnupg | gnupg2 | gnupg1 powermgmt-base default-dbus-session-bus | dbus-session-bus debconf-doc debconf-kde-helper debconf-utils libgtk3-perl libnet-ldap-perl libterm-readline-gnu-perl whiptail | dialog debsig-verify gnupg glibc-doc locales libnss-nis libnss-nisplus rng-tools gnutls-bin libpam-doc pcscd readline-doc bzip2 ncompress xz-utils tar-scripts tar-doc The following NEW packages will be installed: adduser apt apt-utils ca-certificates dbus dbus-bin dbus-daemon dbus-session-bus-common dbus-system-bus-common debconf debconf-i18n dpkg gcc-14-base gpgv libacl1 libapparmor1 libapt-pkg6.0t64 libassuan0 libaudit-common libaudit1 libbz2-1.0 libc6 libcap-ng0 libcap2 libcrypt1 libdb5.3t64 libdbus-1-3 libexpat1 libffi8 libgcc-s1 libgcrypt20 libgmp10 libgnutls30t64 libgpg-error-l10n libgpg-error0 libhogweed6t64 libidn2-0 liblocale-gettext-perl liblz4-1 liblzma5 libmd0 libnettle8t64 libnl-3-200 libnl-genl-3-200 libnl-route-3-200 libnpth0t64 libp11-kit0 libpam-modules libpam-modules-bin libpam0g libpcre2-8-0 libpcsclite1 libreadline8t64 libseccomp2 libselinux1 libsemanage-common libsemanage2 libsepol2 libssl3t64 libstdc++6 libsystemd0 libtasn1-6 libtext-charwidth-perl libtext-iconv-perl libtext-wrapi18n-perl libtinfo6 libudev1 libunistring5 libxxhash0 libzstd1 openssl passwd perl-base readline-common sensible-utils tar ubuntu-keyring zlib1g 0 upgraded, 78 newly installed, 0 to remove and 0 not upgraded. Need to get 0 B/22.6 MB of archives. After this operation, 77.5 MB of additional disk space will be used. Do you want to continue? [Y/n] y E: Cannot get debconf version. Is debconf installed? debconf: apt-extracttemplates failed: 25600 Extracting templates from packages: 38%E: Cannot get debconf version. Is debconf installed? debconf: apt-extracttemplates failed: 25600 Extracting templates from packages: 76%E: Cannot get debconf version. Is debconf installed? debconf: apt-extracttemplates failed: 25600 Extracting templates from packages: 100% E: Sub-process dpkg --set-selections returned an error code (100) E: Couldn't clean the currently selected dpkg states
In this error , is asking is debconf installed , so i tried to install debconf but it showing you have unmet dependencies :
user@omkar:~$ sudo apt-get install debconf
wpasupplicant : Depends: libc6 (>= 2.34) but it is not going to be installed
Depends: libdbus-1-3 (>= 1.9.14) but it is not going to be installed
Depends: libnl-3-200 (>= 3.2.21) but it is not going to be installed
Depends: libnl-genl-3-200 (>= 3.2.7) but it is not going to be installed
Depends: libnl-route-3-200 (>= 3.4.0) but it is not going to be installed
Depends: libpcsclite1 (>= 1.0.0) but it is not going to be installed
Depends: libreadline8t64 (>= 6.0) but it is not going to be installed
Depends: libssl3t64 (>= 3.0.0) but it is not going to be installed
Depends: adduser but it is not going to be installed
It is all going like a circle , i am unable to fix this errors.
