After updating to Ubuntu 24.04 LTS from 22.04 I can no longer share my screen in chrome or firefox.
Im using Gnome (Wayland). It works on X11, but I cant use X11 due to other issues.
I have tried everything mentioned here: Screen sharing with Wayland
If I run chrome in a Terminal and select screen sharing, these errors show up in the terminal:
[25628:25628:0905/162847.590258:ERROR:base_capturer_pipewire.cc(81)] ScreenCastPortal failed: 3
[25628:25628:0905/162847.719072:ERROR:screen_capture_portal_interface.cc(48)] Failed to request session: GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “org.freedesktop.portal.ScreenCast” on object at path /org/freedesktop/portal/desktop
Even though ScreenCast shows up in d-feet: screenshot
Troubleshooting info:
Firefox 130.0 (snap)
Chromium 128.0.6613.84 (snap)
Also tried normal Chrome (non-snap)
Pipewire:
$ systemctl --user status pipewire.socket pipewire
● pipewire.socket - PipeWire Multimedia System Sockets [...]
Active: active (running)
● pipewire.service - PipeWire Multimedia Service [...] Active: active (running)
$ pipewire --version pipewire Compiled with libpipewire 1.0.5 Linked with libpipewire 1.0.5
Wireplumber:
$ systemctl --user status wireplumber
● wireplumber.service - Multimedia Service Session Manager [...]
$ wireplumber --version wireplumber Compiled with libwireplumber 0.4.17 Linked with libwireplumber 0.4.17
xdg-desktop-portal:
$ systemctl --user status xdg-desktop-portal
● xdg-desktop-portal.service - Portal service [...]
$ systemctl --user status xdg-desktop-portal-gnome ● xdg-desktop-portal-gnome.service - Portal service (GNOME implementation) [...] Active: active (running)
$ apt search xdg-desktop-portal | grep "installed" libportal-gtk3-1/noble,now 0.7.1-5build5 amd64 [installed,automatic] libportal-gtk4-1/noble,now 0.7.1-5build5 amd64 [installed,automatic] libportal1/noble,now 0.7.1-5build5 amd64 [installed,automatic] xdg-desktop-portal/noble,now 1.18.3-1ubuntu1 amd64 [installed,automatic] xdg-desktop-portal-gnome/noble,now 46.0-1build1 amd64 [installed] xdg-desktop-portal-gtk/noble,now 1.15.1-1build2 amd64 [installed,automatic] xdg-desktop-portal-kde/noble,now 5.27.11-0ubuntu3 amd64 [installed,automatic]
Wayland stuff:
$ env | grep '^WAYLAND_DISPLAY='
WAYLAND_DISPLAY=wayland-0
$ < "/proc/$(pidof xdg-desktop-portal)/environ" tr '\0' '\n' | grep '^WAYLAND_DISPLAY=' WAYLAND_DISPLAY=wayland-0
$ < "/proc/$(pidof xdg-desktop-portal)/environ" tr '\0' '\n' | grep '^XDG_CURRENT_DESKTOP=' XDG_CURRENT_DESKTOP=ubuntu
$ cat /usr/share/xdg-desktop-portal/gnome-portals.conf [preferred] default=gnome;gtk; org.freedesktop.impl.portal.Secret=gnome-keyring;
karel
  • 122,292
  • 133
  • 301
  • 332
I had this (or a similar) problem, and solved it by installing the package "xdg-desktop-portal" through synaptic. Command line would be
sudo apt install xdg-desktop-portal
I found the solution here: https://www.technowizardry.net/2024/09/screen-sharing-on-wayland-ubuntu-24-04/
Actually, the answer by cardamom was useful but only when following the link. Package xdg-desktop-portal was already installed on my laptop but package xdg-desktop-portal-gnome was missing and THAT was the actual problem. I do think the problem originated in the upgrade from 22 to 24 since in the update Gnome was removed (!!!!) and I had to reinstall it. Obviously the above package is not reinstalled by default...?
