I did search online and here on the forum for similar posts but found none that fits the issue. A Framework laptop bought in 2022 with the following specs:
  • 16GB RAM
  • 11th Gen i5-1135G7 2.4GHzx8
  • Mesa Intel Xe Graphics
  • 500GB SSD
  • running Ubuntu 22.04.4 LTS
  • GNOME 42.9
  • Wayland
There is no driver or software updates available at the moment, as it checks for updates daily.
Everything, except the keyboard and audio, freezes regularly since maybe a week ago. The freeze may occur minutes or hours after boot, regardless of what software I am using. Overheating shouldn't be an issue, as I only use the laptop on a stand with lots of clear room below and do not run anything crazier than Firefox and Discord.
Now, the freeze may disappear after 5-45 minutes, but usually once one has occurred, more follow in quick succession. I can close the laptop to force a login, which fixes the freeze temporarily. Serious work is impossible that way, though.
My attempts
  • run top command -> memory peaks at 3% usage, but CPU sometimes reaches up to 30%
  • check for updates -> none available
  • restart and control temperature when retesting
I'm new to Linux and don't know what logs I could access to give you a better picture, so please bear with me. Everything ran flawlessly for the past six months and I never had to dive into Linux/Ubuntu much at all. What steps should I take to identify the cause and remedy it? Maybe you guys have a hunch what is going on? Thank you.
David DE
  • 2,316
bosen
Edit: I'm Currently on kernel version 6.11 zabbly and the issue came back. It might actually have come back in 6.10 already. I solved it by downgrading to the official 5.15 kernel as suggested by HenrikB. 5.15 was no longer installed so I installed it with:
sudo apt install linux-image-generic
I then configured Grub to remember the last manual selection. Finally, I selected 5.15 at boot. I think that every time there is a kernel update, the order is reset, so I need to manually select 5.15 again.
I'm quite surprised that this bug is lasting so long, I think the X1C is quite popular among Linux users. It would be great if someone could report if the issue exists on Ubuntu 24.04 too.
I had the same issue on my Lenovo Thinkpad X1C Gen 9, very annoying. I think the issue started after an update, probably around mid-August 2024. I don't know what the source of the issue was, but I upgraded the kernel to 6.10 and since then I haven't experienced any freeze.
To update the kernel I used Zabbly's repos -- see instruction in the readme of the repo. The repo should be trusted (the maintainer has worked at Canonical until recently, see here) and the procedure is straightforward, but I did have to disable Secure Boot, which is not great. As soon as I have a moment I'll just upgrade to 24.04 with the official kernel, which I hope is not affected.
korg91
  • 146
