I used to have a dual boot in one of my hard disk drives - Ubuntu and Windows 7. Then, I added a SSD which is now my main hard disk drive, and I'm using it for Windows 7 completely, keeping Ubuntu in the old HD. I restored the Grub so everything works ok, except for one thing.
Everytime I update the grub, it detects two windows:
Found Windows 7 (loader) on /dev/sda1
Found Windows 7 (loader) on /dev/sdb1
Obviously, I don't want it to detect the Windows on sdb1. Because I no longer use it (I manually deleted the files). What can I do about that without wiping out completely the partition?
5 Answers5
I'm not sure what it uses to detect the OS. I'd try a quick reformat of the partitions.
If nothing else works, here is a patch that can be made to /etc/grub.d/30_os-prober that will allow you to specify any partitions you want to skip:
/etc/grub.d/30_os-prober modification
These lines can be added to the file (just past the middle) to skip any partitions that you don't want to show up in the menu. Leaving the string empty will skip nothing.
Add the lines starting with
############## Patch to prevent some partitions being autodetected
through
############## End of patch:
for OS in ${OSPROBED} ; do
  DEVICE="`echo ${OS} | cut -d ':' -f 1`"
  LONGNAME="`echo ${OS} | cut -d ':' -f 2 | tr '^' ' '`"
  LABEL="`echo ${OS} | cut -d ':' -f 3 | tr '^' ' '`"
  BOOT="`echo ${OS} | cut -d ':' -f 4`"
  SKIP_THESE_DEVICES="sdb1"
  # SKIP_THESE_DEVICES="sda1 sdb1 sdb2"   example for multiple devices
  # SKIP_THESE_DEVICES=""                 example for no devices
  PARTITIONNAME="`echo ${DEVICE} | cut -c 6- 2> /dev/null`"
  if [ "`echo ${SKIP_THESE_DEVICES} | grep -e ${PARTITIONNAME} 2> /dev/null`" ] ; then
    continue
  fi
  if [ -z "${LONGNAME}" ] ; then
    LONGNAME="${LABEL}"
  fi
After changing this file, you will, of course, need to run sudo update-grub to regenerate the menu. You should be able to see the results from the terminal's output when it says "Found ..." for each entry; you can run it first before the mods, then compare the output to after the mods. You should not see the removed entries.
Marty Fried
  • 18,944
If Windows 7 is still getting detected, it means that the parition you made still contains some bootloader files of Windows 7. Why not delete the partition itself? That will definitely solve this issue.
I suggest that you keep a backup of any files you want, and delete the partition of your Windows 7 in your old HD. After that update the grub.
I don't think I need to suggest tools to you, but Gparted is the best partition editor from what I know.
You should use a Gparted live cd to delete your windows partition on the old HD. But you may have to fix grub after you do this.
Matthew
  • 71
With grub2, you can skip a device by adding a line similar to the following in your /etc/default/grub file:
GRUB_OS_PROBER_SKIP_LIST="A523009BEFE25938@/dev/sdb1"
GRUB_OS_PROBER_SKIP_LIST is a space-separated list of devices that should be skipped during the os probing stage of update-grub. Each device is of the format <UUID>@<DEVICE>, where DEVICE is the skipped device's path, and UUID is its blkid, which you can obtain by typing:
blkid /dev/sdb1
Once you've updated your /etc/default/grub file, just run update-grub.
sudo update-grub
In the output, you should see if the device was successfully skipped.
Beevik
  • 101
You can use wipefs to wipe the filesystem metadata so that the NTFS Windows partition is no longer detected. You will loose all the data in the partition.
You simply run
sudo wipefs -a /dev/sdb1
The command ends in the second it is run and it is quicker that deleting the partition or deleting the files.
solsTiCe
  • 9,515
