I am not a confident Ubuntu user but changed my password due to unexplained usage issues. I copied carefully the suggested Ubuntu password, but it will not work, neither will the previous one, nor removing the last entry in case I hit backspace.
I tried changing it using this article How do I reset a lost administrative password?, but it will not complete due to a dependency for a USB stick I have not used for ages because it was causing problems.
From GRUB I select the latest Kernel in recovery mode. The screen is pink with the options spread to the right of the options box at increasing indent.
I selected Root Drop to root shell prompt. The result:
[OK] started Avahi mDNS-SD Stack
[OK] Started Cups Scheduler
[OK] Reached target Printer Support
Started Save/Restore Sound Card State...
[OK] Finished Save/Restore Sound Card State
[OK] Reached target Sound Card
[Time] Timed out waiting for device/dev/disk/by-id/usb-UGREEN_MassStorageClass_123426789ABCDE-010
[Depend] Dependency failed for/mnt/usb-UGREEN_MassStorageClass_123426789ABCDE-010
Then I tried again by another option on the same article by editing the Kernel. From GRUB I selected my latest Kernel and pressed e. The result:
set params, with Linux 6.5.0-41-generic
record fail
Load-video
gfx mode $ Linux-gtx-mode
insmod gzio
If [xtgrub_platforms=xxen l: then insmod lzopio fi
insmod part-gpt
insmod ext2
Search -no floppy --fs-uuid --set=root ifzbfc8b-34be-4a7b-93d3-828c6975le71
echo 'LoadingLinux6.5.0-41-generic...
Linux /boot/unilinuz-6.5.0-41 generic root = if2bfc06 ro apm = power_off
initrd /boot/initrd.img-6.5.0-41 generic
There is no line Starting Kernel
If you can see the problem can you advise how to delete the dependency when I can't log in and advice on the best way to recover my password?
