I upgraded last night from Ubuntu 20.04 to 22.04. When I booted up my PC, I found my settings app (gnome-control-center) was gone. I tried to install, but I get:
$ sudo apt install gnome-control-center
Reading package lists... Done
Building dependency tree... Done
libpython3.10 : Depends: libpython3.10-stdlib (= 3.10.12-1~22.04.3) but 3.10.14-1+focal1 is to be installed
This problem has been reported twice here ((1), (2)), but none of the solutions work for me.
Based on the second question linked above, I tried sudo apt remove libpython3.10-stdlib, but I again get the same or a similar error:
python3 : Depends: python3.10 (>= 3.10.6-1~) but it is not going to be installed
Depends: libpython3-stdlib (= 3.10.6-1~22.04) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
I also followed the instructions here.
Contents of sources.list as requested:
# deb cdrom:[Ubuntu 19.10 _Eoan Ermine_ - Release amd64 (20191017)]/ eoan main restricted
# See http://help.ubuntu.com/community/UpgradeNotes for how to upgrade to
# newer versions of the distribution.
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy main restricted
deb-src http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy multiverse restricted universe main #Added by software-properties
# deb-src http://fr.archive.ubuntu.com/ubuntu/ eoan main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-updates main restricted
deb-src http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-updates multiverse restricted universe main #Added by software-properties
# deb-src http://fr.archive.ubuntu.com/ubuntu/ eoan-updates main restricted
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team. Also, please note that software in universe WILL NOT receive any
## review or updates from the Ubuntu security team.
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy universe
# deb-src http://fr.archive.ubuntu.com/ubuntu/ eoan universe
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-updates universe
# deb-src http://fr.archive.ubuntu.com/ubuntu/ eoan-updates universe
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## multiverse WILL NOT receive any review or updates from the Ubuntu
## security team.
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy multiverse
# deb-src http://fr.archive.ubuntu.com/ubuntu/ eoan multiverse
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-updates multiverse
# deb-src http://fr.archive.ubuntu.com/ubuntu/ eoan-updates multiverse
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-backports main restricted universe multiverse
deb-src http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-backports main restricted universe multiverse #Added by software-properties
# deb-src http://fr.archive.ubuntu.com/ubuntu/ eoan-backports main restricted universe multiverse
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-security main restricted
deb-src http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-security multiverse restricted universe main #Added by software-properties
# deb-src http://security.ubuntu.com/ubuntu eoan-security main restricted
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-security universe
# deb-src http://security.ubuntu.com/ubuntu eoan-security universe
deb http://ubuntu-arch.linux.edu.lv/ubuntu/ jammy-security multiverse
# deb-src http://security.ubuntu.com/ubuntu eoan-security multiverse
# This system was installed using small removable media
# (e.g. netinst, live or single CD). The matching "deb cdrom"
# entries were disabled at the end of the installation process.
# For information about how to configure apt package sources,
# deb https://typora.io/linux ./ # disabled on upgrade to focal
# deb-src https://typora.io/linux ./
# see the sources.list(5) manual.
# deb [arch=amd64] https://download.docker.com/linux/ubuntu focal stable # disabled on upgrade to focal
# deb-src [arch=amd64] https://download.docker.com/linux/ubuntu eoan stable
# deb https://crawl.develz.org/debian crawl 0.24 # disabled on upgrade to focal
# deb http://apt.llvm.org/focal/ llvm-toolchain-focal-18 main # disabled on upgrade to jammy
# deb-src http://apt.llvm.org/focal/ llvm-toolchain-focal-18 main
Output of sudo apt-cache policy libpython3.10-stdlib
libpython3.10-stdlib:
Installed: 3.10.14-1+focal1
Candidate: 3.10.14-1+focal1
Version table:
*** 3.10.14-1+focal1 100
100 /var/lib/dpkg/status
3.10.12-1~22.04.3 500
500 http://ubuntu-arch.linux.edu.lv/ubuntu jammy-updates/main amd64 Packages
500 http://ubuntu-arch.linux.edu.lv/ubuntu jammy-security/main amd64 Packages
3.10.4-3 500
500 http://ubuntu-arch.linux.edu.lv/ubuntu jammy/main amd64 Packages
