Long since I tried to make this work, but failed because of lack of knowledge & understanding in the matter.
Situation
Bluetooth works on Windows, albeit not the best. I don't need the Bluetooth, but I want to use an HP Presenter mouse. This worked on Windows, doesn't on Linux, and I believe the hardware to be at fault. Years ago I found a post on Arch detailing how someone made it work, but I couldn't understand what it said, very much like the attached post below, but it ended up being much simpler than first thought.
Specifications
lsusb
Bus 001 Device 002: ID 0bda:57c4 Realtek Semiconductor Corp. HP Truevision HD
Bus 001 Device 003: ID 062a:5110 MosArt Semiconductor Corp. ASUS Zen AIO KB/MS/RF/GOLD
Bus 001 Device 004: ID 0a5c:216d Broadcom Corp. BCM43142A0 Bluetooth 4.0
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
dmesg|egrep -i 'blue|firm'
[    0.681328] ACPI: thermal: [Firmware Bug]: Invalid critical threshold (-274000)
[    0.692346] tpm_crb MSFT0101:00: [Firmware Bug]: Bad ACPI memory layout
[    1.218245] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: 00000000-0000-0000-0000-000000000000 has zero instances
[    1.218253] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: 00000000-0000-0000-0000-000000000000 has zero instances
[    1.218257] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: 00000000-0000-0000-0000-000000000000 has zero instances
[    1.218260] wmi_bus wmi_bus-PNP0C14:00: [Firmware Info]: 00000000-0000-0000-0000-000000000000 has zero instances
[    1.225581] wmi_bus wmi_bus-PNP0C14:01: [Firmware Info]: 8232DE3D-663D-4327-A8F4-E293ADB9BF05 has zero instances
[    1.225586] wmi_bus wmi_bus-PNP0C14:01: [Firmware Info]: 8F1F6436-9F42-42C8-BADC-0E9424F20C9A has zero instances
[    1.225589] wmi_bus wmi_bus-PNP0C14:01: [Firmware Info]: 8F1F6435-9F42-42C8-BADC-0E9424F20C9A has zero instances
[    1.225592] wmi_bus wmi_bus-PNP0C14:01: [Firmware Info]: DF4E63B6-3BBC-4858-9737-C74F82F821F3 has zero instances
[    3.677869] systemd[1]: Mounting snap-firmware\x2dupdater-127.mount - Mount unit for firmware-updater, revision 127...
[    5.781063] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/skl_dmc_ver1_27.bin (v1.27)
[    5.862033] Bluetooth: Core ver 2.22
[    5.864078] NET: Registered PF_BLUETOOTH protocol family
[    5.864083] Bluetooth: HCI device and connection manager initialized
[    5.864147] Bluetooth: HCI socket layer initialized
[    5.864150] Bluetooth: L2CAP socket layer initialized
[    5.864158] Bluetooth: SCO socket layer initialized
[    5.958165] ACPI: video: [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
[    6.037631] Bluetooth: hci0: BCM: chip id 70
[    6.038647] Bluetooth: hci0: BCM: features 0x06
[    6.057361] Bluetooth: hci0: denis-HP-Pavilion-Notebook
[    6.057367] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000
[    6.060776] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[    6.060784] Bluetooth: hci0: BCM: 'brcm/BCM43142A0-0a5c-216d.hcd'
[    6.060788] Bluetooth: hci0: BCM: 'brcm/BCM-0a5c-216d.hcd'
[    7.497292] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    7.497297] Bluetooth: BNEP filters: protocol multicast
[    7.497303] Bluetooth: BNEP socket layer initialized
[    8.123695] Bluetooth: hci0: Opcode 0x1003 failed: -110
[ 1206.241636] Bluetooth: hci0: BCM: chip id 70
[ 1206.242664] Bluetooth: hci0: BCM: features 0x06
[ 1206.258679] Bluetooth: hci0: BCM43142A
[ 1206.258686] Bluetooth: hci0: BCM43142A0 (001.001.011) build 0000
[ 1206.259741] Bluetooth: hci0: BCM: firmware Patch file not found, tried:
[ 1206.259746] Bluetooth: hci0: BCM: 'brcm/BCM43142A0-0a5c-216d.hcd'
[ 1206.259748] Bluetooth: hci0: BCM: 'brcm/BCM-0a5c-216d.hcd'
[ 1208.263754] Bluetooth: hci0: command 0x1003 tx timeout
[ 1208.263756] Bluetooth: hci0: Opcode 0x1003 failed: -110
Similar Posts
I believe this post addresses it, but I tried it and it doesn't work for me. BCM43142A0 Broadcom Bluetooth doesn't work with Ubuntu 18.04
Attempted
  1. Found the Windows .hex file & moved over to Linux,
  2. Ran file through hex2hcd
  3. Copied the result over to /lib/firmware/brcm, titled BCM43142A0_001.001.011.0311.0329.hcd
  4. Rebooted, Failed, so copied & renamed file to lowercase (bcm43142a...) and only beginning, as I think the OP of referenced post did (BCM.hcd).
  5. Rebooted, Failed.
Additional
If I attempt anything else, I will update this post.
Sphor
