I can see that many people have problems with this, but many slightly different answers are adding to my confusion. hoping that someone can guide me through this specifically.
I have a hp notebook 15 with Windows 10 (Bluetooth works there). I repartitioned the drive and installed Ubuntu 18.04 (kernel 4.15.0-33.generic). I managed to configure most everything but blueman tells me there are no adaptors.
When I started, I was getting complaints about missing firmware. I managed to download something (at this point I can't remember exactly what) but now
lsusb gives me
Bus 001 Device 004: ID 0a5c:216c Broadcom Corp. BCM43142A0 Bluetooth Device
grep-ing through dmesg gives me
[ 27.974968] Bluetooth: Core ver 2.22
[ 27.974987] Bluetooth: HCI device and connection manager initialized
[ 27.974990] Bluetooth: HCI socket layer initialized
[ 27.974993] Bluetooth: L2CAP socket layer initialized
[ 27.974999] Bluetooth: SCO socket layer initialized
[ 28.094367] Bluetooth: hci0: BCM: chip id 70
[ 28.095366] Bluetooth: hci0: BCM: features 0x06
[ 28.111368] Bluetooth: hci0: BCM43142A
[ 28.111371] Bluetooth: hci0: BCM (001.001.011) build 0000
[ 30.816147] Bluetooth: hci0: command 0x0a0a tx timeout
[ 35.256748] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 35.256750] Bluetooth: BNEP filters: protocol multicast
[ 35.256754] Bluetooth: BNEP socket layer initialized
[ 38.880071] Bluetooth: hci0: BCM: Patch command 0a0a failed (-110)
[ 41.056139] Bluetooth: hci0: command 0x1001 tx timeout
[ 49.120058] Bluetooth: hci0: BCM: Reading local version info failed (-110)
[ 1637.728121] Bluetooth: hci0: command 0x1001 tx timeout
[ 1645.792154] Bluetooth: hci0: BCM: Reading local version info failed (-110)
At some point I copied
BCM43142A0_001.001.011.0277.0289.hex and BCM43142A0_001.001.011.0311.0328.hex over from the Windows partition, but again, I don't know what to do with them.
I'm not exactly a noob, but the road signs all seem to be written in a language I can't quite translate. Any suggestions/comments would be gratefully appreciated. If I need to post more info, pls tell what else would be useful.
finally i went back to windows, looked in the device manager for the .hex file that windows uses. copied it again to the linux side. ran it through hex2hcd, then moved the output to \lib\firmware\brcm as both BCM.hcd and BCM43142A0-0a5c-216c.hcd based on the info returned by lsusb (Bus 001 Device 004: ID 0a5c:216c Broadcom Corp. BCM43142A0 Bluetooth Device). rebooted one more time, and voila!. it is now working. it seems like i did all this before but apparently not.
how do i mark this question as solved? editing the title tells me that's a no-no.
