After reading the information from my Question pros/cons of PAE , i want to remove PAE kernel because i don't need them . I know removing a kernel from Synaptic Package Manager . Thats easy job but how to get Non-PAE kernel of current ?
Raja G
  • 105,327
  • 107
  • 262
  • 331
To install a different kernel (such as a non-pae kernel), you would need to install the package for it. Use your favourite package manager (like Synaptic) to install linux-image-generic, or use this command in a terminal:
sudo apt-get install linux-image-generic
In Ubuntu 12.04 or earlier version, this will install the latest generic kernel that is not pae. Then you would need to reboot and in the grub menu select the non-pae kernel. Once it boots up, verify everything is working.
In Ubuntu 12.10 or later version, this will NOT work since linux-image-generic is equivelent to linux-image-generic-pae.
Optional: You can remove the other kernel once you know everything is working with the new kernel by doing
sudo apt-get remove linux-image-generic-pae
Vdragon
  • 127
tgm4883
  • 8,062
