I installed Ubuntu on an old iMac Early 2008. Its running well except that the WIFI doesnt work. Ive done the following to try and fix the issue
The WIFI card is a broadcom BCM4321 (Airport Extreme), additional drivers shows 1 proprietary driver in use. Tried reinstalling this, same issue. Ran
sudo apt-get update
sudo apt install firmware-b43-installer
Same issue.
I followed the instructions on this page
"No Wi-Fi Adapter Found", Ubuntu 22.04, Broadcom Wireless Drivers [14e4:4331] (rev 02) MacBook Pro
I downloaded the file and extracted it to my desktop, then ran the terminal commands
cd /usr/lib/firmware
sudo cp ~/Desktop/b43fw_508/b43/* b43
sudo modprobe -r b43 && sudo modprobe b43
I left out mkdir 43 as I was getting an error message that it already existed.
I then ran the following commands instead of the ones listed on the page above because the terminal didn't like the reinstall command.
sudo apt update
The WIFI comes back immediately after doing this, but if I restart, it then things go back to square one.
Does anyone know how to permanently fix the Wi-Fi? Thanks in advance.
