-1
I have a Raspberry Pi 4B 64 bit. I have flashed an Ubuntu Mate 22.04 Desktop 64 bit onto a 64GB SD card with Win32DiskImager (the reason I don't use official Raspberry Pi Imager/Etcher is because the imager cannot validate my SD card for some reason; I have tried another SD card 32GB but still failed).
I wanted to access the RPi 4B with SSH. I have already connected it to the same network with router. I cannot find its IP in my network with Angry IP Scanner or Advanced IP Scanner.
I have tried a method in many older tutorials teaching me to create a "SSH" file and "wpa-supplicant.conf" in the boot partition with the correct Wi-Fi credentials. It didn't work. Also some tutorials also stated this method is no longer relevant in newer versions.
Any advice on what I can do? Highly appreciated!
ps. Ultimately I am trying access the Pi to install LCD package.
FYI: The Pi was actually working fine with Ubuntu Mate Desktop 32-bit with the image provided by the seller with the LCD package and all SSH setting done for me. It's just that I can't seem to replicate the same for 64-bit version if I do everything manually just by myself.
Your router should have the Pi listed, if not then it is not getting an IP address which could be because it is not recognizing the onboard nic/wifi.
motang
