I am using ubuntu 10.10 64bit. The problem is that no VCD's can be played. I tried Totem, mplayer,vlc etc etc. None of the players can render the file and show either show I/O error or parse error. I even tried copying the .dat files but it shows me a permission denied error ( even in root mode file browser). Vcd's work in Windows as well as VCD player. So neither the discs nor the drive is faulty. Any help will be appreciated. Thanks in advance
jrg
  • 61,707
tinhed
  • 2,468
It could be that the data is corrupted. This may be deliberate; used for DRM. See if the method outlined in this answer works.
dv3500ea
  • 37,734
click on open cd/dvd from file menu in vlc if that cd is an vcd that can be played on cd player or perhaps change the player or get codecs for vlc
Install mplayer without gui and try running your video from terminal.I am using it for a longtime and none of the videos failed for me.
sudo aptitude -y install mplayer-nogui
To play video's from terminal type the following,
mplayer /path/to/your/video/file
If you dont want to have mplayer,then i would recommend you to install the following codec pack
sudo apt-get install ubuntu-restricted-extras
Also i recommend you to go through this documentation for detailed instruction and troubleshooting.
karthick87
  • 84,513
