this is a known issue with *ubuntu and Dell laptops, there are hundreds of hits to this question; the webcam is simply not recognized by the system and one needs to add a ppa repo (this one: ppa:oem-solutions-engineers/oem-projects-meta) and stuff is sort of solved (alternatively, the solution is simlar and asks to add libcamhal).
I solved the problem before on my Dell, that way.
But: now that I updated to 24.04 it is of course no more, since that ppa repo does not work with 24.04.
Solutions?
I thought of
  • forcing Kubuntu to accept the old (22.04) version of that repo. But I fail. Any hint on how to do this?
  • waiting for the 24.04 repo to be available... but that might be a long wait and I need my webcam now.
Thanks!
I add here some diagnostics as asked in the comments (thanks).
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 24.04 LTS
Release:        24.04
Codename:       noble
Also, the webcam is now seen by the system (I added the ipu6 module to the kernel and libcamhal):
v4l2-ctl --list-devices
Intel MIPI Camera (platform:v4l2loopback-000):
        /dev/video0
But the camera seems to be UNCLAIMED
sudo lshw -C multimedia
  *-multimedia:0 UNCLAIMED
       description: Multimedia controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 5
       bus info: pci@0000:00:05.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress pm cap_list
       configuration: latency=0
       resources: iomemory:620-61f memory:628e000000-628effffff
The problem has been solved as of July 11th, 2024: Ubuntu posted an updated Kernel that fixed the problem for the 24.04 issue.
In particular, the update involved the packages
linux-modules-6.8.0-1007-oem:amd64 (6.8.0-1007.7, automatic), linux-modules-ipu6-oem-24.04a:amd64 (6.8.0-1007.7), linux-modules-ipu6-6.8.0-1007-oem:amd64 (6.8.0-1007.7, automatic), linux-image-6.8.0-1007-oem:amd64 (6.8.0-1007.7, automatic)
The answer here worked for me on Dell Precision 5690.
As in that answer, I did:
sudo apt install linux-modules-ipu6-generic
sudo apt install ubuntu-oem-keyring # necessary for the following repository
sudo add-apt-repository deb http://dell.archive.canonical.com/ noble somerville
sudo apt install libcamhal0
then restarted my machine and the webcam works now. Although the video quality is pretty bad (when you move its very laggy and leaves a trail and has what looks like heavy compression effects). Looking at reviews like this one, it should be quite good quality.
Garrett
  • 730
