I have just upgraded from ubuntu 22.04 to 24.04 LTS. Everything's fine but Internet is not working after being connected.
In my case, I deleted /etc/resolv.conf, renamed /etc/resolv.conf.old to /etc/resolv.conf, and the internet was back. After that the systemd-resolved was installaed to avoid any conflict:
sudo apt install systemd-resolved
- 1,340
Upgraded Dell Latitude from 22.04 to 24.04. No internet. Nothing worked.
I changed /etc/NetworkManager/conf.d/dhcp-client.conf to include only
[main]
dhcp=dhcpcd
And then sudo systemctl restart NetworkManager
If this solved your problem, let me know. I spent 4 hours & I don't think, it's worth it. But, if this helps then it'll be.
Have a good one.
- 191
- 1
- 7
Known problem https://bugs.launchpad.net/ubuntu/+source/network-manager/+bug/2055012
The problem was this: /etc/resolv.conf became a broken link along with systemd-resolve.service. I had to delete them both and write a new resolv.conf to fix the error.
- 31
I had the same issue and I will post my solution because I had to combine two of the above (the problem was indeed the bronken /etc/resolv.conf link):
1 rm /etc/resolv.conf
2 sudo dhcpcd (after this I gained access to internet again, necessary for step 3, but in navbar still looked disconnected)
3 sudo apt install systemd-resolved (after this navbar show me connected and everything was fine)
- 23
This issue is due to a broken symlink on /etc/resolv.conf follow below commands to fix it
- rm /etc/resolv.conf
- sudo dhcpcd
This should fix the problem
- 11
If you're encountering this issue, you can check the status of systemd-resolved using the following command:
sudo systemctl status systemd-resolved.service
In my case, it was both inactive and masked. If that's also the case for you, follow these steps:
Unmask the service (only if it's masked):
sudo systemctl unmask systemd-resolved.serviceStart the service:
sudo systemctl start systemd-resolved.serviceEnable the service (to ensure it starts automatically on boot):
sudo systemctl enable systemd-resolved.service
These steps resolved the issue for me.
- 111
The issue arises because your previous DHCP network configuration is likely lost after a system upgrade. This is often due to the introduction of netplan, a new network configuration tool that uses systemd-networkd or NetworkManager as renderers. Consequently, simply reinstalling NetworkManager or systemd-resolved will not permanently resolve the problem.
Solution: Recreate DHCP Configuration
While manually starting dhcpcd might provide a temporary fix, the configuration will not persist after a reboot. Therefore, recreating the DHCP configuration is the recommended approach.
Configuration for systemd-networkd (for systems using systemd-resolved):
According to the ArchWiki, if you are using systemd-resolved, the configuration for wired connections should be as follows:
Create or edit the file
/etc/systemd/network/20-wired.networkand add the following content:[Match] Name=en*[Link] RequiredForOnline=routable
[Network] DHCP=yes
[Match] Name=en*: Matches all network interfaces that start withen(typically wired network cards).[Network] DHCP=yes: Enables DHCP.[Link] RequiredForOnline=routable: According to Archwiki's Explaination
prevent systemd-networkd-wait-online.service from exiting before network interfaces have a routable IP address (and thus having other services that require a working network connection starting too early)
Configuration for NetworkManager:
If you are using NetworkManager, according to the ArchWiki, the configuration should be as follows:
- Create or edit the file
/etc/NetworkManager/conf.d/dhcp-client.confand add the following content: prevent systemd-networkd-wait-online.service from exiting before network interfaces have a routable IP address (and thus having other services that require a working network connection starting too early),
[main]
dhcp=dhcpcd
[main] dhcp=dhcpcd: TellsNetworkManagerto usedhcpcdas the DHCP client.
- 11
- 2
I have faced the same issue in ubuntu:24.04 following solution is working for me. internet issue in ubuntu 24.04
