I am having a strange issue. I accidentally upgrade to nvidia-driver-550 and I am having serious lagging issues.
It's quite noticeable when using the keyboard or clocking around.
How do I know the lagging is GPU related?
  • I reverted to nouveau driver and everything works amazing however due to the number of screen I have the CPU just goes nuts so I want to use the GPU.
What have I tried?
  • I have tried using ubuntu-drivers to install version 525. But it think it's already installed.
  • I have purged all nvidia using sudo apt-get --purge remove *nvidia*
  • I have tried installing 525 as follows sudo apt install nvidia-driver-525
    • However if you study the packages it just reinstall 550 after rebooting you can see it's 550 not 525.
    udo apt-get install nvidia-driver-535
    Reading package lists... Done
    Building dependency tree... Done
    The following additional packages will be installed:
      dctrl-tools dkms libnvidia-cfg1-550 libnvidia-common-550 libnvidia-compute-550 libnvidia-decode-550 libnvidia-egl-wayland1 libnvidia-encode-550 libnvidia-extra-550
      libnvidia-fbc1-550 libnvidia-gl-550 nvidia-compute-utils-550 nvidia-dkms-550 nvidia-driver-550 nvidia-firmware-550-550.54.14 nvidia-kernel-common-550 nvidia-kernel-source-550
      nvidia-settings nvidia-utils-550 screen-resolution-extra xserver-xorg-video-nvidia-550
    Suggested packages:
      debtags menu
    Recommended packages:
      libnvidia-compute-550:i386 libnvidia-decode-550:i386 libnvidia-encode-550:i386 libnvidia-fbc1-550:i386 libnvidia-gl-550:i386
    The following NEW packages will be installed:
      libnvidia-fbc1-550 libnvidia-gl-550 nvidia-compute-utils-550 nvidia-dkms-550 nvidia-driver-535 nvidia-driver-550 nvidia-firmware-550-550.54.14 nvidia-kernel-common-550
      nvidia-kernel-source-550 nvidia-settings nvidia-utils-550 screen-resolution-extra xserver-xorg-video-nvidia-550
    0 upgraded, 22 newly installed, 0 to remove and 0 not upgraded.
    Need to get 10.6 kB/284 MB of archives.
    After this operation, 721 MB of additional disk space will be used.
  • I have tried installing 525-open but I get the error below
    sudo apt install nvidia-driver-525-open
    The following packages have unmet dependencies: nvidia-driver-525-open : Depends: libnvidia-gl-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: nvidia-dkms-525-open (<= 525.147.05-1) Depends: nvidia-dkms-525-open (>= 525.147.05) Depends: nvidia-kernel-common-525 (<= 525.147.05-1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: nvidia-kernel-source-525-open (= 525.147.05-0ubuntu0.22.04.1) but it is not going to be installed Depends: libnvidia-compute-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: libnvidia-extra-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: nvidia-compute-utils-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: libnvidia-decode-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: libnvidia-encode-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: nvidia-utils-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: xserver-xorg-video-nvidia-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: libnvidia-cfg1-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Depends: libnvidia-fbc1-525 (= 525.147.05-0ubuntu0.22.04.1) but 550.54.14-1pop0~1709151545~22.04~c91e06a~dev is to be installed Recommends: nvidia-prime (>= 0.8) Recommends: libnvidia-compute-525:i386 (= 525.147.05-0ubuntu0.22.04.1) but it is not installable Recommends: libnvidia-decode-525:i386 (= 525.147.05-0ubuntu0.22.04.1) but it is not installable Recommends: libnvidia-encode-525:i386 (= 525.147.05-0ubuntu0.22.04.1) but it is not installable Recommends: libnvidia-fbc1-525:i386 (= 525.147.05-0ubuntu0.22.04.1) but it is not installable Recommends: libnvidia-gl-525:i386 (= 525.147.05-0ubuntu0.22.04.1) but it is not installable E: Unable to correct problems, you have held broken packages.
  • I have tried install nvidia-dkms-525 to try resolve the last issue but no luck.
I am out of ideas and I only solution is to reinstall and setup my dev machine which is a pain in the but to be honest
I am running Ubuntu 22.04.4 LTS
Current nvidia driver and card
| NVIDIA-SMI 550.54.14              Driver Version: 550.54.14      CUDA Version: 12.4     |
| GPU  Name                 Persistence-M | Bus-Id          Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |           Memory-Usage | GPU-Util  Compute M. |
|                                         |                        |               MIG M. |
|   0  NVIDIA GeForce RTX 3070 ...    Off |   00000000:01:00.0  On |                  N/A |
| N/A   56C    P8             19W /   80W |     428MiB /   8192MiB |      0%      Default |
|                                         |                        |                  N/A |
+-----------------------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=========================================================================================| | 0 N/A N/A 2300 G /usr/lib/xorg/Xorg 205MiB | | 0 N/A N/A 2449 G /usr/bin/gnome-shell 94MiB | | 0 N/A N/A 3085 G ...yOnDemand --variations-seed-version 47MiB | | 0 N/A N/A 3266 G ...seed-version=20240401-050216.270000 35MiB | | 0 N/A N/A 5917 G ...sion,SpareRendererForSitePerProcess 33MiB | +-----------------------------------------------------------------------------------------+
Check if the issue is related to input delay on Terminal Ubuntu 22.04.4
If so, you shall fix the lag using mutter provided by this ppa:
sudo add-apt-repository ppa:vanvugt/mutter
sudo apt update
sudo apt upgrade
Gorgo
  • 156
