Since my upgrade to Ubuntu 22.04 LTS, the battery indicator shows "not charging" when the charger is plugged in while the battery is full. This could be correct but confusing. When the battery is not completely full and charging, it shows only the remaining battery life and percentage as if it was running from the battery Does this is any Software glitch ??? because i also used Ubuntu 23 on same laptop there is no such problem i face. only ubuntu 22.04 have this problem how to fix it......
Asked
Active
Viewed 1,083 times
-1
That is a normal behavior for some laptops. I use a IdeaPad 330 at work and had that same "issue", at first I thought the plug was damaged. If you want a better explanation check these links.
karel
- 122,292
- 133
- 301
- 332
