Today I have acquired a new laptop, Maibenben X565, with preinstalled Kubuntu based on Ubuntu 22.10. I downloaded an ISO image of the regular Ubuntu 23.10 from the official site, created an ISO image on a USB, rebooted the system and then tried to install Ubuntu 23.10 using live USB. The keyboard works just fine with the preinstalled Kubuntu or in the BIOS menu, but stops working when I launch "try to install Ubuntu".
EDIT:
First, my laptop does not have a touch screen. It does not have an fn button to disable the keyboard. The menu "Keyboard" in Ubuntu Settings does not contain any information on the keyboard or on lack of thereof. Using screen keyboard, I ran sudo lshw upon launching live USB with Ubuntu 23.10, and the keyboard is not listed in the list of input devices (while the touchpad is). In /dev/input/by-path, there is no folder for keyboard. The command
cat /sys/class/dmi/id/chassis_type
suggested in an answer to this post, returns 10. However, I am not sure if it solves the problem, for once, because the bug described there appears to be at least 3 years old, and its unlikely that it hasn't been fixed yet (a comment in the linked posts suggests the bug was fixed already in the kernel version 5.4, and the current kernel version is 6.something). Another reason is that the solution there suggests you should reboot the system, but for me, this bug occurs already when launching the system from the live boot USB, meaning, in order to apply the solution there, I would need to first install the new Ubuntu, and for that I either need to destroy the current Kubuntu 22.10 build, in which at least the keyboard works, or to partition the hard drive and install Ubuntu 23.10 alongside with Kubuntu 22.10, when try to fix the bug, and then reinstall the whole system again if the fix works, so this will only be my last resort if nothing else works.
Besides, the recommendation there is not applicable to my case anyway, because I have AMD CPU, not Intel, and so I doubt blacklisting intel_vbtn could help.
EDIT 2: Eventually I have tried the only solution proposed under the suggested question that was at least possible to perform in my situation, namely, I installed Ubuntu using the screen keyboard and then blacklisted intel_vbtn. I don't have dual boot Windows, I don't have slow keys mode activated, my keyboard is not a detachable USB device, my kernel version is higher than 5.20, and my laptop is not even aware that its built-in keypad exists, it does not disable it recieving a signal of touchscreen activation or something. sudo libinput debug-events does not detect any SW_TABLET_MODE events. In fact, I am suspicious that somehow the keyboard is recognized as a Video Bus, since two Video Buses are detected for some reason.
EDIT 3:
Here is the result of running sudo lshw -businfo:
Bus info Device Class Description
system Typhoon Series (X565)
bus X565
memory 64KiB BIOS
memory 384KiB L1 cache
memory 3MiB L2 cache
memory 16MiB L3 cache
cpu@0 processor AMD Ryzen 5 6600H with Radeon Graphics
memory 16GiB System Memory
memory 8GiB SODIMM Synchronous Unbuffered (Unregistered) 4800 MHz (0.2 ns)
pci@0000:00:00.0 bridge Family 17h-19h PCIe Root Complex
pci@0000:00:00.2 generic Family 17h-19h IOMMU
pci@0000:00:01.1 bridge Advanced Micro Devices, Inc. [AMD]
pci@0000:01:00.0 display GA107M [GeForce RTX 3050 Mobile]
pci@0000:01:00.1 card0 multimedia NVIDIA Corporation
input10 input HDA NVidia HDMI/DP,pcm=8
input11 input HDA NVidia HDMI/DP,pcm=9
input8 input HDA NVidia HDMI/DP,pcm=3
input9 input HDA NVidia HDMI/DP,pcm=7
pci@0000:00:02.1 bridge Family 17h-19h PCIe GPP Bridge
pci@0000:02:00.0 eno1 network RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
pci@0000:00:02.2 bridge Family 17h-19h PCIe GPP Bridge
pci@0000:03:00.0 wlp3s0 network MT7921K (RZ608) Wi-Fi 6E 80MHz
pci@0000:00:02.4 bridge Family 17h-19h PCIe GPP Bridge
pci@0000:04:00.0 /dev/nvme0 storage YMTC PC300-512GB-B
hwmon3 disk NVMe disk
/dev/ng0n1 disk NVMe disk
nvme@0:1 /dev/nvme0n1 disk 512GB NVMe disk
nvme@0:1,1 /dev/nvme0n1p1 volume 1074MiB Windows FAT volume
nvme@0:1,2 /dev/nvme0n1p2 volume 475GiB EXT4 volume
pci@0000:00:08.1 bridge Family 17h-19h Internal PCIe GPP Bridge
pci@0000:05:00.0 display Rembrandt [Radeon 680M]
pci@0000:05:00.2 generic VanGogh PSP/CCP
pci@0000:05:00.3 bus Rembrandt USB4 XHCI controller #3
usb@1 usb1 bus xHCI Host Controller
usb@1:3 multimedia HD Webcam
usb@2 usb2 bus xHCI Host Controller
pci@0000:05:00.4 bus Rembrandt USB4 XHCI controller #4
usb@3 usb3 bus xHCI Host Controller
usb@3:3 communication Wireless_Device
usb@4 usb4 bus xHCI Host Controller
pci@0000:05:00.5 multimedia ACP/ACP3X/ACP6x Audio Coprocessor
pci@0000:05:00.6 card1 multimedia Family 17h/19h HD Audio Controller
input12 input HD-Audio Generic Mic
input13 input HD-Audio Generic Headphone
pci@0000:00:08.3 bridge Family 17h-19h Internal PCIe GPP Bridge
pci@0000:06:00.0 bus Rembrandt USB4 XHCI controller #8
usb@5 usb5 bus xHCI Host Controller
usb@5:1 bus Hub
usb@6 usb6 bus xHCI Host Controller
pci@0000:06:00.3 bus Rembrandt USB4 XHCI controller #5
usb@7 usb7 bus xHCI Host Controller
usb@8 usb8 bus xHCI Host Controller
pci@0000:06:00.4 bus Rembrandt USB4 XHCI controller #6
usb@9 usb9 bus xHCI Host Controller
usb@10 usb10 bus xHCI Host Controller
pci@0000:00:14.0 bus FCH SMBus Controller
pci@0000:00:14.3 bridge FCH LPC Bridge
system PnP device PNP0c01
system PnP device PNP0b00
input PnP device PNP0303
system PnP device PNP0c02
pci@0000:00:01.0 bridge Family 17h-19h PCIe Dummy Host Bridge
pci@0000:00:02.0 bridge Family 17h-19h PCIe Dummy Host Bridge
pci@0000:00:03.0 bridge Family 17h-19h PCIe Dummy Host Bridge
pci@0000:00:04.0 bridge Family 17h-19h PCIe Dummy Host Bridge
pci@0000:00:08.0 bridge Family 17h-19h PCIe Dummy Host Bridge
pci@0000:00:18.0 bridge Rembrandt Data Fabric: Device 18h; Function 0
pci@0000:00:18.1 bridge Rembrandt Data Fabric: Device 18h; Function 1
pci@0000:00:18.2 bridge Rembrandt Data Fabric: Device 18h; Function 2
pci@0000:00:18.3 bridge Rembrandt Data Fabric: Device 18h; Function 3
pci@0000:00:18.4 bridge Rembrandt Data Fabric: Device 18h; Function 4
pci@0000:00:18.5 bridge Rembrandt Data Fabric: Device 18h; Function 5
pci@0000:00:18.6 bridge Rembrandt Data Fabric: Device 18h; Function 6
pci@0000:00:18.7 bridge Rembrandt Data Fabric: Device 18h; Function 7
/dev/fb0 display EFI VGA
input0 input Power Button
input1 input Sleep Button
input14 input UNIW0001:00 093A:0255 Mouse
input15 input UNIW0001:00 093A:0255 Touchpad
input16 input Bluetooth 3.0 Keyboard
input2 input Lid Switch
input6 input Video Bus
input7 input Video Bus
The Bluetooth keyboard is an external device used instead of the built-in keyboard.
EDIT 4:
I also tried the thing described here, namely changing a line in /etc/default/grub to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash i8042.nopnp=1 i8042.dumbkbd=1", then running sudo update-grub and restarting. Also didn't help. Also, my installation of Ubuntu uses x11, not Wayland.
