Issue
Some graphical applications will return this error in the terminal and refuse to run. This issue appeared after a recent update and upgrade
DRI driver not from this Mesa build ('23.2.1-1ubuntu3.1~22.04.2' vs '24.1~git2403020600.63d2aa~oibaf~j (git-63d2aa4 2024-03-02 jammy-oibaf-ppa)')
failed to load driver: radeonsi
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 130
Current serial number in output stream: 131
Kernel: 5.15.0-92-generic
WM: dwm
window system display server: x11/xorg
I am using the kernals amggpu driver
output of lshw -c video
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:03:00.0
logical name: /dev/fb0
version: c4
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=amdgpu latency=0 resolution=1920,1080
resources: irq:42 memory:c0000000-cfffffff memory:d0000000-d01fffff ioport:1000(size=256) memory:d0500000-d057ffff memory:c0000-dffff
output of lspci -k | grep -A 3 -E "(VGA|3D)"
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] (rev c4)
Subsystem: Lenovo Picasso
Kernel driver in use: amdgpu
Kernel modules: amdgpu
output of inxi -G
Graphics:
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
driver: amdgpu v: kernel
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
Display: server: X.Org v: 1.21.1.4 driver: X: loaded: amdgpu gpu: amdgpu
resolution: 1920x1080~60Hz
OpenGL: renderer: N/A v: N/A
I'm assuming that this is happening because I have no renderer for OpenGL
Things I've tried
- Installing the latest stable version of Mesa driver
- Using
amd-installcommand to install the amd gpu stack - Uninstalling and reinstalling x11, xorg, and xserver-xorg-video-amdgpu
- Installing freeglut3-dev (OpenGL)
I've since removed the removed the ppa for the latest version of the mesa driver because that did not fix the issue. I also removed amdgpu-install because installing the amd gpu stack did not fix the issue either.
When I installed the amd gpu stack some graphical applications like glxinfo (but not my window manager dwm) would return a segfault
