TL;DR
Use this command if you installed the driver via "Additional drivers" tab of the "Software & Updates"
sudo ubuntu-drivers install nvidia:VERSION
where VERSION is the version you want to install.
Full answer
The command (as suggested by this answer)
sudo apt purge 'nvidia.*'
did not work as the driver was not installed via apt but via the "Additional drivers" tab of the "Software & Updates" application.
I was able to install the driver (nvidia-driver-550) using the command (I found here)
This was probably working because 550 is the currently latest version. In case you want to install a specific version, use this command:
where VERSION is the version you want to install. It might be that some versions are not compatible with certain kernel versions as described here.
Steps
Now to the steps of what I had to do:
Enter the installation command into the
This might take a while to download. After the download finished, the terminal was going blank (i.e. all characters and symbols disappeared). I panicked a bit but everything was actually fine. Then a "terminal screen" appeared to setup secure boot.
In case you have already done this, it might be that the remaining of this question (except maybe a reboot) is not needed.
Using the arrow-keys and TAB (select) and Enter (confirm) one can navigate the menus that are presented. In the menu it prompts you to setup a password which you have to enter after a reboot to confirm you are allowed to do this change.
Enter the password once and contine, then reenter the same password again for confirmation.
After the process is done, the terminal can be closed and the computer has to be rebooted.
There (at least on my system) a screen appeared with multiple options, including "enroll MOK". Select this option. After that you can view the key, as I knew what it was about I just confirmed. Then one has to enter the password previously setup for secure boot. Once this step is done, select "reboot".
After the reboot the driver should be installed correctly.
