I did some troubleshooting by running a restart, checking the status of the Bluetooth, removing and reinstalling it, and whatnot. But whatever I did the best I was able to do was to my headphones got connected but the sound was coming from the laptop speaker and not from the headphones.
● bluetooth.service - Bluetooth service
     Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor pre>
     Active: active (running) since Mon 2024-02-26 07:06:42 IST; 3s ago
       Docs: man:bluetoothd(8)
   Main PID: 4623 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 8702)
     Memory: 768.0K
        CPU: 55ms
     CGroup: /system.slice/bluetooth.service
             └─4623 /usr/lib/bluetooth/bluetoothd
Feb 26 07:06:42 asus systemd[1]: Starting Bluetooth service... Feb 26 07:06:42 asus bluetoothd[4623]: Bluetooth daemon 5.64 Feb 26 07:06:42 asus systemd[1]: Started Bluetooth service. Feb 26 07:06:42 asus bluetoothd[4623]: Starting SDP server Feb 26 07:06:42 asus bluetoothd[4623]: Bluetooth management interface 1.22 init> Feb 26 07:06:42 asus bluetoothd[4623]: src/adapter.c:reset_adv_monitors_complet> Feb 26 07:06:42 asus bluetoothd[4623]: Failed to clear UUIDs: Failed (0x03) Feb 26 07:06:42 asus bluetoothd[4623]: Failed to add UUID: Failed (0x03) Feb 26 07:06:42 asus bluetoothd[4623]: Failed to add UUID: Failed (0x03) Feb 26 07:06:42 asus bluetoothd[4623]: Failed to add UUID: Failed (0x03)
This is the current status. Can anyone help me resolve this out? I am a new user of Ubuntu. Thanks
Hi Daniel, Thanks for responding to the question. One thing that got correct after following your answer that I did not get any error in status check
[sudo] password for raghu:
     Active: active (running) since Mon 2024-02-26 20:17:45 IST; 4min 46s ago
   Main PID: 762 (bluetoothd)
     Status: "Running"
     Memory: 2.2M
        CPU: 119ms
             └─762 /usr/lib/bluetooth/bluetoothd -d
Feb 26 20:22:26 asus bluetoothd[762]: src/adapter.c:start_discovery_timeout() Feb 26 20:22:26 asus bluetoothd[762]: src/adapter.c:start_discovery_timeout() a> Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:discovering_callback() hci0> Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:trigger_start_discovery() Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:cancel_passive_scanning() Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:start_discovery_timeout() Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:start_discovery_timeout() a> Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:start_discovery_timeout() s> Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:start_discovery_complete() > Feb 26 20:22:27 asus bluetoothd[762]: src/adapter.c:discovering_callback() hci0> lines 1-22/22 (END)
Here is the full log of journalctl -r -b -0 -u bluetooth you can have a look at it
Feb 26 20:19:56 asus bluetoothd[762]: src/device.c:device_set_legacy() legacy 0
Feb 26 20:19:56 asus bluetoothd[762]: src/adapter.c:device_found_callback() hci>
Feb 26 20:19:51 asus bluetoothd[762]: src/adapter.c:discovering_callback() hci0>
Feb 26 20:19:51 asus bluetoothd[762]: src/adapter.c:start_discovery_complete() >
Feb 26 20:19:51 asus bluetoothd[762]: src/adapter.c:start_discovery_timeout() s>
Feb 26 20:19:51 asus bluetoothd[762]: src/adapter.c:start_discovery_timeout() a>
Feb 26 20:19:51 asus bluetoothd[762]: src/adapter.c:cancel_passive_scanning()
Feb 26 20:19:51 asus bluetoothd[762]: src/adapter.c:trigger_start_discovery()
Feb 26 20:19:50 asus bluetoothd[762]: src/adapter.c:cancel_passive_scanning()
Feb 26 20:19:50 asus bluetoothd[762]: src/adapter.c:trigger_start_discovery()
Feb 26 20:19:50 asus bluetoothd[762]: src/adapter.c:resume_discovery()
Feb 26 20:19:50 asus bluetoothd[762]: src/device.c:device_bonding_failed() stat>
Feb 26 20:19:50 asus bluetoothd[762]: src/device.c:device_bonding_complete() bo>
Feb 26 20:19:50 asus bluetoothd[762]: src/adapter.c:bonding_attempt_complete() >
Feb 26 20:19:50 asus bluetoothd[762]: plugins/policy.c:disconnect_cb() reason 1
Feb 26 20:19:50 asus bluetoothd[762]: src/adapter.c:adapter_remove_connection()
Feb 26 20:19:50 asus bluetoothd[762]: src/adapter.c:dev_disconnected() Device 4>
Feb 26 20:19:49 asus bluetoothd[762]: src/device.c:device_set_rssi_with_delta()>
Feb 26 20:19:49 asus bluetoothd[762]: src/device.c:device_set_legacy() legacy 0
Feb 26 20:19:49 asus bluetoothd[762]: src/adapter.c:device_found_callback() hci>
Thanks once again.
This is caused by Bluetooth being disabled. Check for any hardware switches first. Then run the following to enable it:
rfkill unblock all
reboot
If you still see the error, we can reinstall BlueZ:
sudo rm -rf /var/lib/bluetooth /etc/bluetooth
apt download bluez
sudo dpkg -P --force-all bluez
sudo dpkg -i ./bluez*.deb
That should reinstall BlueZ. If BlueZ is still broken, please add the -d flag to the ExecStart line in /lib/systemd/system/bluetooth.service , reboot, and attach the full log of journalctl -r -b -0 -u bluetooth .
Daniel T
  • 5,339
