When there's trouble, it might be good to understand what happens under the covers to sign a user into a GUI session and get a Unity (or other window manager) to bring up a desktop.
How a desktop user GUI session gets started with Ubuntu 12.04-14.04
Here's the chain of events:
The Ubuntu Linux kernel and upstart
The kernel starts the init process as process number 1. This is upstart for Ubuntu 12.04.
Upstart jobs are in /etc/init/
Man page: man init
Logs: kernel log (dmesg; copied to /var/log/syslog), /var/log/upstart/jobname.log, other logs determined by started jobs.
Source: /etc/init/lightdm.conf
The upstart job executes /usr/sbin/lightdm . We probably can expect this to be converted to a systemd service unit over time.
Lightdm
Man page: man lightdm
, Also: Ubuntu Wiki: LightDM
Logs:
/var/log/syslog
/var/log/lightdm/lightdm.log
/var/log/lightdm/*
for PAM:
/var/log/auth.log
for the Xorg X server:
/var/log/Xorg.0.log
Source: man lightdm and /var/log/lightdm/lightdm.log
lightdm get's started fairly late in the init process; For example, the system dbus must to be already started, the filesystem has to be ready, and the graphics display system must be ready.
lightdm creates an xauthority file and then starts X, starting it on VT 7, the virtual terminal you get if you press Alt+Ctrl+F7. When X is started lightdm signals for the Plymouth splash screen program to quit. It's essential that this happens after all of the tty's (1-6) have started.
Since July 2013 Mir support items have been added to lightdm, but those aren't used by default for desktop systems as of 14.04.
X attempts to use the most advanced drivers possible. It's own drivers are loaded from /usr/lib/xorg/modules/ . Note that there exist both kernel drivers and xorg drivers for many devices, with the xorg drivers almost certainly using the kernel ones. dri and glx are important features, in particular, for advanced high performance graphics. Logs are stored for X in /var/log/Xorg.0.log .
There is communications over the system dbus about this "seat" and possible user names are acquired. lightdm uses X to draw the screen. unity-greeter is used to assist in the process.
As you select the various possible userid's that userid's backgound image is used.
lightdm get's the names of potential window-managers/systems from /usr/share/xsessions/*.desktop.
Account information is acquired via the accountsservice accounts-daemon over dbus.
lightdm and the greeter use PAM to authenticate the user. Once authenticated, PAM will start a gnome-keyring-daemon daemon with the
--login option and feed it the user's password so that it can unlock the user's login keyring, if present. See https://live.gnome.org/GnomeKeyring/Pam and man 8 pam_unix for more information. PAM stores log information in /var/log/auth.log and is controlled by /etc/pam.conf (almost empty) and /etc/pam.d/*. In particular, see /etc/pam.d/lightdm and /etc/pam.d/lightdm-autologin.
Once the user is authenticated privileges are dropped and a file is written to ~user/.dmrc describing the session. For example:
[Desktop]
Session=ubuntu
or
[Desktop]
Session=awesome
The .desktop files from /usr/share/xsessions/*.desktop now determine the rest of the startup sequence.
For example here's the one for Unity:
[Desktop Entry]
Name=Ubuntu
Comment=This session logs you into Ubuntu
Exec=gnome-session --session=ubuntu
TryExec=unity
Icon=
Type=Application
X-Ubuntu-Gettext-Domain=gnome-session-3.0
The /usr/sbin/lightdm-session shell script is run with the arguments gnome-session --session=ubuntu
(sic.--'ubuntu', not 'unity')
lightdm-session
Logs: ?
Error Logs: ~/.xsession-errors
Started Process Logs: ~/.cache/upstart/*
Source: /usr/sbin/lightdm-session
/usr/sbin/lightdm-session then takes these steps:
Runs:
/etc/profile, $HOME/.profile/etc/xprofile $HOME/.xprofile;loads resources from
/etc/X11/Xresourcesand$HOME/.Xresources, if they exist, loads the keyboard map with setxbmap using the contents of/etc/X11/Xkbmapand$HOME/.Xkbmap;if not using XKB uses xmodmap against any existing
/etc/X11/Xmodmapand$HOME/.Xmodmapruns scripts in
/etc/X11/xinit/xinitrc.d;runs the Xsession scripts in
/etc/X11/Xsession.d/*, using the options in/etc/X11/Xsession.options.One of these starts ssh-agent (redundant), another executes
$HOME/.xsessionrc. Another starts session-dbus (both ssh-agent and session-dbus as allowed in the aboveXsession.optionsfile). This session dbus is useful for communications between processes regarding this single user session.
ssh-agent can hold onto ssh keys for the session if they are ssh-add 'ed some time during the session, but gnome-keyring-daemon does the same thing.
/etc/X11/Xsession.d/50_check_unity_support runs /usr/lib/nux/unity_support_test and if it fails exports LIBGL_ALWAYS_SOFTWARE=1 to the environment so that llvmpipe will be used to software render the desktop.
Starting with Ubunu 13.10:
/etc/X11/Xsession.d/00upstart sets variable UPSTART to 1.
/etc/X11/Xsession.d/99upstart checks that variable and if set substitutes init --user
to the other items set to $STARTUP. Thus user-mode upstart starts those upstart jobs in /usr/share/upstart/sessions. One of those is gnome-session.conf which starts gnome-session.
Unless already done, finally lightdm-session starts a window manager, or for unity, the above starts the gnome-session session manager.
It appears that lightdm-session takes on the traditional role of xsession. Its man page is at http://manpages.ubuntu.com/manpages/precise/man5/Xsession.5.html . lightdm considers it to be a session-wrapper.
gnome-session session manager (Unity and Gnome Shells)
Manpage: http://manpages.ubuntu.com/manpages/precise/en/man1/gnome-session.1.html
Logs: ?
Source: man page
gnome-session is used for Unity, but not for awesome by default, for example. See the above .desktop files.
gnome-session starts the specified program from /usr/share/gnome-session/sessions/ and starts applications from ~/.config/autostart/ and /etc/xdg/autostart.
Here's one example from /etc/xdg/autostart:
$cat /etc/xdg/autostart/nm-applet.desktop
[Desktop Entry]
Name=Network
Comment=Manage your network connections
Icon=nm-device-wireless
Exec=nm-applet
Terminal=false
Type=Application
NoDisplay=true
NotShowIn=KDE;
X-GNOME-Bugzilla-Bugzilla=GNOME
X-GNOME-Bugzilla-Component=general
X-GNOME-Autostart-enabled=true
X-Ubuntu-Gettext-Domain=nm-applet
Another, /etc/xdg/autostart/gnome-keyring-ssh.desktop, starts gnome-keyring-daemon with the --start option, completing the start of that daemon process and storing important information about it in the environment for potential use by ssh.
From a ps aux list it appears that gnome-session starts window managers with dbus-launch.
Window Managers
Awesome Window Manager
Man page: http://manpages.ubuntu.com/manpages/precise/en/man1/awesome.1.html
Logs: ?
Source: man page, config file examination
Here's the awesome.desktop file in /usr/share/xsessions/ used by lightdm-session:
[Desktop Entry]
Encoding=UTF-8
Name=awesome
Comment=Highly configurable framework window manager
TryExec=awesome
Exec=awesome
As you can see, the entry simply causes the awesome window manager to be executed. It reads its own configuration files, including /etc/xdg/awesome/rc.lua from the awesome package. It can be configured with $HOME/.config/awesome/rc.lua.
Unity
Source: config file examination
Here's the ubuntu.desktop file in /usr/share/xsessions/ :
[Desktop Entry]
Name=Ubuntu
TryExec=unity
Icon=
Type=Application
This starts the gnome session described in /usr/share/gnome-session/sessions/ubuntu.session
Here is that file:
[GNOME Session]
Name=Ubuntu
RequiredComponents=gnome-settings-daemon;
RequiredProviders=windowmanager;panel;
DefaultProvider-windowmanager=compiz
DefaultProvider-panel=compiz
IsRunnableHelper=/usr/lib/nux/unity_support_test
FallbackSession=ubuntu-2d
DesktopName=Unity
The IsRunnableHelper program run by gnome-session in 12.04 determines whether unity can be run or whether ubuntu-2d will run. If it makes a mistake and says unity can run and it cannot, there's trouble. Choose ubuntu-2d manually in lightdm if that happens to you. While it returns a return code, we can see what it is doing by running it with the -p option.
$ /usr/lib/nux/unity_support_test -p
OpenGL vendor string: X.Org R300 Project
OpenGL renderer string: Gallium 0.4 on ATI RS690
OpenGL version string: 2.1 Mesa 8.0.2
Not software rendered: yes
Not blacklisted: yes
GLX fbconfig: yes
GLX texture from pixmap: yes
GL npot or rect textures: yes
GL vertex program: yes
GL fragment program: yes
GL vertex buffer object: yes
GL framebuffer object: yes
GL version is 1.4+: yes
Unity 3D supported: yes
For 12.10 and later unsupported hardware uses llvmpipe software to render what the hardware can't. Its configuration file is simpler than the above. See above for how it is enabled.
We can see from the above files that gnome-session must start the settings daemon, and start compiz for purposes of running a window manager and any panels.
compiz
Man page: http://manpages.ubuntu.com/manpages/precise/en/man1/compiz.1.html
Logs: ?
Source: http://en.wikipedia.org/wiki/Compiz, file system examination
Once compiz is started, it runs various plugins. Before 12.10 gnome-settings are used to define these. They can be changed with ccsm (compiz config settings manager) or with gconf-editor. The plugin settings are stored in apps/compiz-1/general/screen0/options under active_plugins. Duplicates have caused me to have segfaults with compiz. These are stored in the user's home directory in the ~/.gconf/ directory organized as above. The actual values are stored in %gconf.xml files there.
Since 12.10 these plugins are stored in binary in your ~/.config/dconf/user file. The dconf, or gsettings method of storing settings is newer. You can see all of these settings with dconf dump /org/gnome/.
Unityshell is one of these plugins. It uses the nux project as an embeded toolkit. Images are drawn on textures in 3 dimensional space with specified transparency values. These are processed by compiz and sent to either llvm or to advanced graphics drivers to have the graphics engines on the system's computer graphic hardware composite and render them. Generally, this is as opposed to rendering images directly to a framebuffer as was done more traditionally. This complicated chain of events is what requires more advanced drivers, and sometimes prompts the use of proprietary graphics drivers in Ubuntu.
- 13,436
