I would like to upload text files to a site so I can share with others.
The sites that I use only allow pictures.
Have you tried pastebinit
https://help.ubuntu.com/community/Pastebinit
pastebinit can be installed in all currently supported versions of Ubuntu with the following command:
sudo apt install pastebinit
It's frequently used in bug reporting, IRC & other docs for sharing text files.
Copying from the link I provided:
Once you have pastebinit installed it's time to test it out.
The command for pastebinit in the terminal is:
<command> | pastebinitFor example if you were having grub issues and someone in the IRC ask you to post your menu.lst into a pastebin you would enter the following in a terminal:
cat /boot/grub/menu.lst | pastebinit
