As detailed in this question following a recent update I am now unable to alter the screen resolution to anything other than 1920 x 1080. This appears to have been the reason why initially when logging in I got nothing but a blank screen and my original question revolved around that. However the real problem seems to be that any setting other than 1920 x 1080 simply does not work (and I had previously had 1280 x 720 as my default setting that Ubuntu was trying to log in with). As my real problem seems to be changing the screen resolution, I thought I'd open a new question.
- OS Name: Ubuntu 22.04.3 LTS
- Hardware Model: Lenovo ThinkPad E15 Gen 3
- Graphics: RENOIR (renoir, LLVM 15.0.7, DRM 3.54, 6.5.0-14-generic)
Until a recent update I was happily using Ubuntu with a screen resolution of 1280 x 720. Now if I go to Settings > Screen Display and attempt to select any other option than 1920 x 1080 the screen goes black for 20 seconds after pressing apply and then comes back firmly on 1920 x 1080.
Attempting xrandr --output XWAYLAND0 --mode 1280x720 in the terminal gives:
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 139 (RANDR)
Minor opcode of failed request: 7 (RRSetScreenSize)
Serial number of failed request: 22
Current serial number in output stream: 23
If I try an older version of 22.04 which I installed from 1280 x 720 works absolutely fine, just as it has done for nearly 2 years.
I would greatly appreciate any help in changing the resolution back to 1280 x 720 and 1920 x 1080 is almost illegibly tiny on my small laptop screen.
