10
How can I get my ATI / AMD drivers to work with any kernel above 3.2.0.x ?
WHAT DID WORK
Installed original AMD64 version of Ubuntu 12.04 ISO image. Burned DVD and installed which shown kernel 3.2.0-23 to begin with. Got 5.1 surround sound working. Got ATI ( Now its AMD ) video drivers installed for my Radeon HD R6870 Video card from AMD's website. fglrxinfo came up and reported as normal.
THE PROBLEM
Kernel 3.2.0.x kept locking up so I tried higher kernel versions. But ATI / AMD Drivers do not install on any kernel Above 3.2.0.x
WHAT I HAVE TRIED
I have gone over this tutorial many times ( https://help.ubuntu.com/community/BinaryDriverHowto/ATI ) and it doesn't work on ANY kernel except 3.2.0.x.
The problems I am having here are that the ATI / AMD drivers working for the 12.04 Precise with kernel 3.2.0-23 and 24, But the computer kept locking up. Although all my games would work, the lock ups were random and were constant. So I looked all over the web for 3 days trying to find an answer and the lock up issue was said to just update the kernel. So I did. Have tried many kernels. All of them .. no lock ups. BUT the Restricted AMD drivers from the AMD website will not install. And none of the OpenSource AMD drivers have EVER installed no matter what Kernel or version I tried.
EXAMPLE OUTPUT OF 3D TYPE OF ERRORS
Javax.media.opengl.GLException: glXGetConfig failed: error code GLX_NO_EXTENSION
at com.sun.opengl.impl.x11.X11GLDrawableFactory.glXGetConfig(X11GLDrawableFactory.java:651)
at com.sun.opengl.impl.x11.X11GLDrawableFactory.xvi2GLCapabilities(X11GLDrawableFactory.java:350)
at com.sun.opengl.impl.x11.X11GLDrawableFactory.chooseGraphicsConfiguration(X11GLDrawableFactory.java:174)
at javax.media.opengl.GLCanvas.chooseGraphicsConfiguration(GLCanvas.java:520)
at javax.media.opengl.GLCanvas.<init>(GLCanvas.java:131)
at haven.HavenPanel.<init>(HavenPanel.java:68)
at haven.HavenPanel.<init>(HavenPanel.java:78)
at haven.MainFrame.<init>(MainFrame.java:182)
at haven.MainFrame.main2(MainFrame.java:306)
at haven.MainFrame.access$100(MainFrame.java:34)
at haven.MainFrame$7.run(MainFrame.java:360)
at java.lang.Thread.run(Thread.java:722)
And of course this is what fglrxinfo shows :
X Error of failed request:  BadRequest (invalid request code or no such operation)
  Major opcode of failed request:  139 (ATIFGLEXTENSION)
  Minor opcode of failed request:  66 ()
  Serial number of failed request:  13
  Current serial number in output stream:  13
EDIT : I forgot to mention that I DID look at this post over the last few days and it did not help.
TorakTu
  • 156
There are two driver options that usually work well:
  • the opensource radeon driver
  • the fglrx package from the official repository
A 64-bit kernel usually gets much better support in this case.
You can also try the 12.6 beta drivers from AMD.
If you need a guide, try the Unofficial Wiki for the AMD Linux Driver.
Do not install a new driver package over an old one. Remember to uninstall the previous package(s).
belacqua
  • 23,540
user827992
  • 2,901
I'm running Ubuntu 12.04 with kernel 3.2.0-26 and had a nightmare getting the ATI and catalyst drivers installed. I'm running a Radeon hd5xxx card and had tried and failed to install the drivers. This is what worked for me as I had a broken installation that wouldn't reinstall and gave me the same DKMS error.
I also followed the binary driver, but as it relies on the uninstall being OK, which mine wasn't, it was useless and refused to fix my driver. I finally amalgamated several fixes from different sites to get mine working.
I did this after using recovery console to get some display back. I had access to synaptic at the time so hopefully you have access.
First thing I did was to add a repository and added all the updates. Graphics failed as I expected.
sudo add-apt-repository ppa:gnome3-team/gnome3
This added some libs that the main repository didn't have and fixed a few other issues too.
Then:
  1. sudo cp /etc/X11/xorg.conf /etc/X11/xorg.conf.BAK - for safety
  2. sudo rm /usr/share/ati/fglrx-uninstall.sh - stops the purge from failing without doing anything at all.
  3. sudo apt-get remove --purge fglrx* (Had errors but carried on)
  4. sudo rm -rf /usr/share/lib/fglrx
  5. sudo rm -rf /usr/share/lib32/fglrx
  6. open synaptic and mark fglrx for installation. This finally added the driver.
  7. with synaptic again, add the ATI catalyst control center.
After reboot, I had issues with my dual screens but as catalyst was installed, I fixed this and now everything works. It even sorted out a flashing I got when moving windows across the dual screens or when activating rotation of desktop cube.
Nephente
  • 5,875
The new AMD 12.11 beta drivers (released 2012.10.23) will work with newer kernels (in my case they are working with 3.5). However to install them you must first install linux-headers-generic. Hence:
    sudo apt-get install linux-headers-generic
You will have to reinstall them from the command line every time you have a kernel update (ctrl+alt+F1 to get to a console in low-graphics mode).
Run the driver as sudo, and use the --force option, e.g.:
    sudo ./amd-driver-installer-catalyst-12.11-beta-x86.x86_64 --force
P.S. This script will get rid of the watermark.
