I have been having trouble getting Ubuntu to control the fans instead of the BIOS on my Dell XPS 13 9315. I have tried most things suggested online, but two problems persist:
i8kctlreturns -1s:
1.0 1.1 JRM8DY3 -1 -1 -1 -1 -1 -1 -1
dell-bios-fan-controlfrom https://github.com/TomFreudenberg/dell-bios-fan-control doesn't appear to be disabling BIOS fan control. It runs successfully:
$ sudo ./dell-bios-fan-control 0
BIOS CONTROL DISABLED
But the fans still keep being controlled by the BIOS (yes, secure boot is disabled).
I have tried most suggestions online (c.f. Dell XPS 15 9570 - How to control the fans?, I've also tried fancontrol, but this gives /usr/sbin/pwmconfig: There are no pwm-capable sensor modules installed). I am loading dell-smm-hwmon by having dell-smm-hwmon present in /etc/modules, and /etc/modprobe.d/dell-smm-hwmon.conf contains:
options dell-smm-hwmon restricted=0 force=1 ignore_dmi=1
Regardless, I see the following error:
$ sudo dmesg | grep dell
[ 11.201781] dell_smm_hwmon: Unable to get Dell SMM signature
It seems that, after sensors-detect, the dell_smm sensor is not present:
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +40.0°C
dell_ddv-virtual-0
CPU Fan: 3093 RPM
CPU: +44.0°C (low = +0.0°C, high = +0.0°C)
Ambient: +39.0°C (low = +0.0°C, high = +0.0°C)
SODIMM: +38.0°C (low = +0.0°C, high = +0.0°C)
Ambient: +38.0°C (low = +0.0°C, high = +0.0°C)
Ambient: +34.0°C (low = +0.0°C, high = +0.0°C)
Unknown: +27.0°C (low = +0.0°C, high = +0.0°C)
ucsi_source_psy_USBC000:002-isa-0000
Adapter: ISA adapter
in0: 5.00 V (min = +5.00 V, max = +5.00 V)
curr1: 0.00 A (max = +0.00 A)
nvme-pci-0100
Adapter: PCI adapter
Composite: +30.9°C (low = -0.1°C, high = +82.8°C)
(crit = +84.8°C)
Sensor 1: +30.9°C (low = -273.1°C, high = +65261.8°C)
coretemp-isa-0000
Package id 0: +34.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +34.0°C (high = +100.0°C, crit = +100.0°C)
Core 4: +33.0°C (high = +100.0°C, crit = +100.0°C)
Core 8: +31.0°C (high = +100.0°C, crit = +100.0°C)
Core 9: +31.0°C (high = +100.0°C, crit = +100.0°C)
Core 10: +31.0°C (high = +100.0°C, crit = +100.0°C)
Core 11: +31.0°C (high = +100.0°C, crit = +100.0°C)
Core 12: +31.0°C (high = +100.0°C, crit = +100.0°C)
Core 13: +31.0°C (high = +100.0°C, crit = +100.0°C)
Core 14: +31.0°C (high = +100.0°C, crit = +100.0°C)
Core 15: +31.0°C (high = +100.0°C, crit = +100.0°C)
ucsi_source_psy_USBC000:001-isa-0000
in0: 14.30 V (min = +5.00 V, max = +14.30 V)
curr1: 3.81 A (max = +0.75 A)
BAT0-acpi-0
Adapter: ACPI interface
in0: 13.26 V
curr1: 1000.00 uA
Interestingly, after a recent kernel upgrade, the dell_ddv-virtual-0 sensor appeared, reporting fan RPM (this wasn't there before). I was having difficulty finding anything about this online, but I was hoping it could potentially help in getting Ubuntu to control the fan instead of the BIOS.
I am looking for advice to get the dell_smm sensor and dell-bios-fan-control working so that I can use i8kmon to take care of fan control and make my laptop quieter. Thanks in advance!
System information:
$ uname -a
Linux smartfridge 6.5.0-14-generic #14~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Mon Nov 20 18:15:30 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
Additionally, my BIOS was recently updated, so it's on the most recent version.
