32
I'm trying to have everything ready to install a new desktop with a few command line instructions. Unfortunately, to install the language packages, I couldn't find how to do it.
I can run
gnome-language-selector
But it doesn't seems to be usable in command line directly. I need to go on with clicks...
An other thing that could be done is that I do those clicks and find out which packages have been installed and read the changes in /etc/environment and /etc/default/locale (and other /etc/... file?) but the list of packages is probably different depending on the packages installed (Firefox, Thunderbird, LibreOffice, Gnome, ...)
Is there a tool for that? Like let's say:
gnome-language-selector --install fr
or a package that has all necessary dependencies:
sudo apt-get install super-language-pack-fr
wjandrea
  • 14,504
samb
  • 1,336
For desktop you can
sudo apt-get install language-pack-[cod] language-pack-gnome-[cod] language-pack-[cod]-base language-pack-gnome-[cod]-base
But each applications can have its language pack. To know the packages to be installed try:
check-language-support -l [cod]
For example:
check-language-support -l fr
jasmines
  • 11,311
20
Auto install all dependencies:
sudo apt -y install $(check-language-support -l fr)
Where fr is the desired two-letter (ISO 639-1) language code.
Pablo Bianchi
  • 17,371
Nuno Mourinho
  • 201
First, you need to edit the locale.gen file.
sudo vim /etc/locale.gen
Then looking for the language pack you need and remove the comment mark, for example, if I want to install zh_CN.GBK GBK zh_CN.UTF8, I just remove the # symbol in these lines, alternatively, you can also add your lines directly into the file. Finally, run:
sudo locale-gen
This is the simplest way I found online.
Gary
  • 51
-1
To add french language to Ubuntu using the Software Center:
Install via the software center
Quoted from there:
This metapackage depends on all packages that provide native language support for applications. (like spell checkers, dictionaries, OpenOffice and Mozilla locale packages, etc.).
If you also want your applications and the desktop to be translated, please additionally install language-pack-fr.
So it may not have the language for certain programs.
To add a language to Ubuntu using the Command line:
Just press Ctrl+Alt+T on your keyboard to open Terminal. When it opens, run the commands below.
sudo apt-get install language-support-fr
Mitch
  • 109,787
