I have just reinstalled Ubuntu after messing things up with chown in root directory.
I'm trying to save a new mount point for second hdd. sdb1 partition is already formatted as ext4.
The problem began when root directory on sda2 was running out of storage. I thought I had dropbox and megasync installed on sdb1 but the synced files were using storage in 2 locations. I uninstalled both apps from sda1 but it made no difference.
The mount point for sdb1 was originally /media but this path lead straight to root directory and was depleting storage. So I moved sdb1 to a new mount directory /hdd. This didn't solve the problem because that path also leads to root directory.
All tutorials I can find recommend mounting a second drive at either /hdd or /media. But if these are leading straight back to sda2 root partition, then surely I am going to quickly run in to the same problem. Then what is the point of having a second drive if it has to mount on the first drive?
I figure that I have misunderstood something fundamental - can someone please explain in plain speak what I am doing wrong and what I should do to mount the second drive so that I don't use up sda2 and so I can easily save large files to sdb1.
Ideally, I'd like Dropbox and Megasync files to sync to sdb1. If that's not possible I can stop them syncing. As a minimum I'd like sdb1 accessible in Dolphin so that I can save large files and backups there without encroaching on sda2 space.
Thanks in advance.
Operating System: Ubuntu Studio 22.04
KDE Plasma Version: 5.24.7
KDE Frameworks Version: 5.92.0
Qt Version: 5.15.3
Kernel Version: 6.2.0-1018-lowlatency (64-bit)
Graphics Platform: X11
Processors: 12 × Intel® Xeon® CPU E5-1650 v3 @ 3.50GHz
Memory: 31.3 GiB of RAM
Graphics Processor: Quadro K2200/PCIe/SSE2
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 4K 1 loop /snap/bare/5
loop1 7:1 0 63.4M 1 loop /snap/core20/1974
loop2 7:2 0 237.2M 1 loop /snap/firefox/2987
loop3 7:3 0 349.7M 1 loop /snap/gnome-3-38-2004/143
loop4 7:4 0 91.7M 1 loop /snap/gtk-common-themes/1535
loop5 7:5 0 53.3M 1 loop /snap/snapd/19457
sda 8:0 1 238.5G 0 disk
├─sda1 8:1 1 300M 0 part /boot/efi
└─sda2 8:2 1 238.2G 0 part /var/snap/firefox/common/host-hunspell
sdb 8:16 1 1.8T 0 disk
└─sdb1 8:17 1 1.8T 0 part
sr0 11:0 1 1024M 0 rom
