I just installed Ubuntu 22.04.3 LTS and the wifi doesn't work. I've been trying to solve the problem with the different methods mentioned here, but i guess i don't understand enough to be able to fix is. A lot of the stuff people say i don't fully understand and i just try commands. I hope somebody will have the patience to help me fix this.
I tried the answers on https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/
Intel AX201 Wi-Fi 6 is not working on Ubuntu 21.04
Add the lastest intel ax201 wireless firmware work on Ubuntu 20.04
But those didn't work, maybe because i did something wrong. For the second solution i ran into the problem not really knowing if i cloned the right thing, i only did
git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/linux-firmware.git
sudo cp iwlwifi-*.{ucode,pnvm} /lib/firmware/
For the suggested
sudo apt install linux-image-6.5.0-14-generic linux-modules-extra-6.5.0-14-generic linux-headers-6.5.0-14-generic
it gave:
nina@nina-Aspire-A315-58:~$ sudo apt install linux-image-6.5.0-14-generic linux-modules-extra-6.5.0-14-generic linux-headers-6.5.0-14-generic [sudo] password for nina: Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Unable to locate package linux-image-6.5.0-14-generic E: Couldn't find any package by glob 'linux-image-6.5.0-14-generic' E: Unable to locate package linux-modules-extra-6.5.0-14-generic E: Couldn't find any package by glob 'linux-modules-extra-6.5.0-14-generic' E: Unable to locate package linux-headers-6.5.0-14-generic E: Couldn't find any package by glob 'linux-headers-6.5.0-14-generic' nina@nina-Aspire-A315-58:~$
I tried How can I resolve this problem : Unable to locate package linux-image-extra-4.15.0-29-generic but didn't work :(
Some output: *-network
description: Network controller
product: Wi-Fi 6 AX201
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
version: 20
width: 64 bits
clock: 33MHz
capabilities: bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: iomemory:600-5ff irq:16 memory:6003204000-6003207fff
uname -r
6.2.0-37-generic
sb_release -a
No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 22.04.3 LTS Release: 22.04 Codename: jammy
sudo dmesg | grep iwl [sudo] password for nina: [ 2.119839] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver [ 2.119859] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37 [ 2.120298] iwlwifi 0000:00:14.3: loaded firmware version 72.daa05125.0 QuZ-a0-hr-b0-72.ucode op_mode iwlmvm [ 2.278645] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x351 [ 2.499689] iwlwifi 0000:00:14.3: Detected RF HR1 B3, rfid=0x10c000 [ 3.514640] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms). [ 3.515772] iwlwifi 0000:00:14.3: Start IWL Error Log Dump: [ 3.515783] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6 [ 3.515789] iwlwifi 0000:00:14.3: Loaded firmware version: 72.daa05125.0 QuZ-a0-hr-b0-72.ucode [ 3.515796] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN [ 3.515803] iwlwifi 0000:00:14.3: 0x000022F0 | trm_hw_status0 [ 3.515808] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1 [ 3.515813] iwlwifi 0000:00:14.3: 0x004CC13E | branchlink2 [ 3.515818] iwlwifi 0000:00:14.3: 0x004C25DE | interruptlink1 [ 3.515823] iwlwifi 0000:00:14.3: 0x004C25DE | interruptlink2 [ 3.515827] iwlwifi 0000:00:14.3: 0x004CADF8 | data1 [ 3.515831] iwlwifi 0000:00:14.3: 0x01000000 | data2 [ 3.515836] iwlwifi 0000:00:14.3: 0x00000000 | data3 [ 3.515840] iwlwifi 0000:00:14.3: 0x00000000 | beacon time [ 3.515845] iwlwifi 0000:00:14.3: 0x00124BBE | tsf low [ 3.515849] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi [ 3.515854] iwlwifi 0000:00:14.3: 0x00000000 | time gp1 [ 3.515858] iwlwifi 0000:00:14.3: 0x0012A748 | time gp2 [ 3.515862] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type [ 3.515867] iwlwifi 0000:00:14.3: 0x00000048 | uCode version major [ 3.515872] iwlwifi 0000:00:14.3: 0xDAA05125 | uCode version minor [ 3.515877] iwlwifi 0000:00:14.3: 0x00000351 | hw version [ 3.515882] iwlwifi 0000:00:14.3: 0x00C89001 | board version [ 3.515886] iwlwifi 0000:00:14.3: 0x8002FC12 | hcmd [ 3.515891] iwlwifi 0000:00:14.3: 0x00020000 | isr0 [ 3.515895] iwlwifi 0000:00:14.3: 0x00000000 | isr1 [ 3.515899] iwlwifi 0000:00:14.3: 0x08F00002 | isr2 [ 3.515904] iwlwifi 0000:00:14.3: 0x00C0000C | isr3 [ 3.515908] iwlwifi 0000:00:14.3: 0x00000000 | isr4 [ 3.515912] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id [ 3.515917] iwlwifi 0000:00:14.3: 0x004CADF8 | wait_event [ 3.515921] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control [ 3.515926] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration [ 3.515930] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid [ 3.515934] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match [ 3.515943] iwlwifi 0000:00:14.3: 0x0000000B | lmpm_pmg_sel [ 3.515951] iwlwifi 0000:00:14.3: 0x00000000 | timestamp [ 3.515957] iwlwifi 0000:00:14.3: 0x00000020 | flow_handler [ 3.516016] iwlwifi 0000:00:14.3: Start IWL Error Log Dump: [ 3.516021] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7 [ 3.516027] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST [ 3.516032] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1 [ 3.516037] iwlwifi 0000:00:14.3: 0x80455E9C | umac branchlink2 [ 3.516041] iwlwifi 0000:00:14.3: 0x8047257E | umac interruptlink1 [ 3.516046] iwlwifi 0000:00:14.3: 0xC00815B4 | umac interruptlink2 [ 3.516051] iwlwifi 0000:00:14.3: 0x01000000 | umac data1 [ 3.516055] iwlwifi 0000:00:14.3: 0xC00815B4 | umac data2 [ 3.516060] iwlwifi 0000:00:14.3: 0x00000000 | umac data3 [ 3.516064] iwlwifi 0000:00:14.3: 0x00000048 | umac major [ 3.516068] iwlwifi 0000:00:14.3: 0xDAA05125 | umac minor [ 3.516073] iwlwifi 0000:00:14.3: 0x0012A746 | frame pointer [ 3.516077] iwlwifi 0000:00:14.3: 0xC0887EFC | stack pointer [ 3.516082] iwlwifi 0000:00:14.3: 0x00010C00 | last host cmd [ 3.516086] iwlwifi 0000:00:14.3: 0x00000000 | isr status reg [ 3.516117] iwlwifi 0000:00:14.3: IML/ROM dump: [ 3.516122] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state [ 3.516145] iwlwifi 0000:00:14.3: 0x00005629 | IML/ROM data1 [ 3.516173] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0 [ 3.516197] iwlwifi 0000:00:14.3: Fseq Registers: [ 3.516217] iwlwifi 0000:00:14.3: 0x20000000 | FSEQ_ERROR_CODE [ 3.516238] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION [ 3.516259] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION [ 3.516280] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION [ 3.516301] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION [ 3.516323] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN [ 3.516344] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID [ 3.516364] iwlwifi 0000:00:14.3: 0x00000501 | FSEQ_CNVR_ID [ 3.516385] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP [ 3.516408] iwlwifi 0000:00:14.3: 0x00000501 | CNVR_AUX_MISC_CHIP [ 3.516430] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM [ 3.516452] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR [ 3.872084] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110 [ 3.884400] iwlwifi 0000:00:14.3: retry init count 0 [ 3.890257] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x351 [ 5.022475] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms). [ 5.023620] iwlwifi 0000:00:14.3: Start IWL Error Log Dump: [ 5.023623] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6 [ 5.023625] iwlwifi 0000:00:14.3: Loaded firmware version: 72.daa05125.0 QuZ-a0-hr-b0-72.ucode [ 5.023626] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN [ 5.023628] iwlwifi 0000:00:14.3: 0x000022F0 | trm_hw_status0 [ 5.023629] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1 [ 5.023630] iwlwifi 0000:00:14.3: 0x004CC13E | branchlink2 [ 5.023631] iwlwifi 0000:00:14.3: 0x004C25DE | interruptlink1 [ 5.023632] iwlwifi 0000:00:14.3: 0x004C25DE | interruptlink2 [ 5.023632] iwlwifi 0000:00:14.3: 0x004CADF8 | data1 [ 5.023633] iwlwifi 0000:00:14.3: 0x01000000 | data2 [ 5.023634] iwlwifi 0000:00:14.3: 0x00000000 | data3 [ 5.023635] iwlwifi 0000:00:14.3: 0x00000000 | beacon time [ 5.023636] iwlwifi 0000:00:14.3: 0x0010B73C | tsf low [ 5.023637] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi [ 5.023638] iwlwifi 0000:00:14.3: 0x00000000 | time gp1 [ 5.023639] iwlwifi 0000:00:14.3: 0x00111256 | time gp2 [ 5.023639] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type [ 5.023640] iwlwifi 0000:00:14.3: 0x00000048 | uCode version major [ 5.023641] iwlwifi 0000:00:14.3: 0xDAA05125 | uCode version minor [ 5.023642] iwlwifi 0000:00:14.3: 0x00000351 | hw version [ 5.023643] iwlwifi 0000:00:14.3: 0x18C89001 | board version [ 5.023644] iwlwifi 0000:00:14.3: 0x8002FC12 | hcmd [ 5.023645] iwlwifi 0000:00:14.3: 0x00020000 | isr0 [ 5.023646] iwlwifi 0000:00:14.3: 0x00000000 | isr1 [ 5.023647] iwlwifi 0000:00:14.3: 0x08F00002 | isr2 [ 5.023647] iwlwifi 0000:00:14.3: 0x00C0000C | isr3 [ 5.023648] iwlwifi 0000:00:14.3: 0x00000000 | isr4 [ 5.023649] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id [ 5.023650] iwlwifi 0000:00:14.3: 0x004CADF8 | wait_event [ 5.023651] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control [ 5.023652] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration [ 5.023653] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid [ 5.023653] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match [ 5.023654] iwlwifi 0000:00:14.3: 0x0000000B | lmpm_pmg_sel [ 5.023655] iwlwifi 0000:00:14.3: 0x00000000 | timestamp [ 5.023656] iwlwifi 0000:00:14.3: 0x00000020 | flow_handler [ 5.023694] iwlwifi 0000:00:14.3: Start IWL Error Log Dump: [ 5.023695] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7 [ 5.023696] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST [ 5.023697] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1 [ 5.023698] iwlwifi 0000:00:14.3: 0x80455E9C | umac branchlink2 [ 5.023699] iwlwifi 0000:00:14.3: 0x8047257E | umac interruptlink1 [ 5.023700] iwlwifi 0000:00:14.3: 0xC0081632 | umac interruptlink2 [ 5.023701] iwlwifi 0000:00:14.3: 0x01000000 | umac data1 [ 5.023703] iwlwifi 0000:00:14.3: 0xC0081632 | umac data2 [ 5.023704] iwlwifi 0000:00:14.3: 0x00000000 | umac data3 [ 5.023706] iwlwifi 0000:00:14.3: 0x00000048 | umac major [ 5.023707] iwlwifi 0000:00:14.3: 0xDAA05125 | umac minor [ 5.023709] iwlwifi 0000:00:14.3: 0x00111254 | frame pointer [ 5.023710] iwlwifi 0000:00:14.3: 0xC0887EFC | stack pointer [ 5.023712] iwlwifi 0000:00:14.3: 0x00010C00 | last host cmd [ 5.023714] iwlwifi 0000:00:14.3: 0x00000004 | isr status reg [ 5.023735] iwlwifi 0000:00:14.3: IML/ROM dump: [ 5.023737] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state [ 5.023762] iwlwifi 0000:00:14.3: 0x00005648 | IML/ROM data1 [ 5.023772] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0 [ 5.023779] iwlwifi 0000:00:14.3: Fseq Registers: [ 5.023781] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE [ 5.023784] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION [ 5.023787] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION [ 5.023790] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION [ 5.023793] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION [ 5.023796] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN [ 5.023798] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID [ 5.023801] iwlwifi 0000:00:14.3: 0x00000501 | FSEQ_CNVR_ID [ 5.023804] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP [ 5.023809] iwlwifi 0000:00:14.3: 0x00000501 | CNVR_AUX_MISC_CHIP [ 5.023831] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM [ 5.023836] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR [ 5.378542] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110 [ 5.390497] iwlwifi 0000:00:14.3: retry init count 1 [ 5.398182] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6 AX101, REV=0x351 [ 6.746641] iwlwifi 0000:00:14.3: WRT: Collecting data: ini trigger 13 fired (delay=0ms). [ 6.747762] iwlwifi 0000:00:14.3: Start IWL Error Log Dump: [ 6.747769] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 6 [ 6.747774] iwlwifi 0000:00:14.3: Loaded firmware version: 72.daa05125.0 QuZ-a0-hr-b0-72.ucode [ 6.747778] iwlwifi 0000:00:14.3: 0x00000084 | NMI_INTERRUPT_UNKNOWN [ 6.747784] iwlwifi 0000:00:14.3: 0x000022F0 | trm_hw_status0 [ 6.747787] iwlwifi 0000:00:14.3: 0x00000000 | trm_hw_status1 [ 6.747791] iwlwifi 0000:00:14.3: 0x004CC13E | branchlink2 [ 6.747795] iwlwifi 0000:00:14.3: 0x004C25DE | interruptlink1 [ 6.747798] iwlwifi 0000:00:14.3: 0x004C25DE | interruptlink2 [ 6.747802] iwlwifi 0000:00:14.3: 0x004CADF8 | data1 [ 6.747805] iwlwifi 0000:00:14.3: 0x01000000 | data2 [ 6.747808] iwlwifi 0000:00:14.3: 0x00000000 | data3 [ 6.747811] iwlwifi 0000:00:14.3: 0x00000000 | beacon time [ 6.747814] iwlwifi 0000:00:14.3: 0x0010A77C | tsf low [ 6.747818] iwlwifi 0000:00:14.3: 0x00000000 | tsf hi [ 6.747821] iwlwifi 0000:00:14.3: 0x00000000 | time gp1 [ 6.747824] iwlwifi 0000:00:14.3: 0x00110259 | time gp2 [ 6.747827] iwlwifi 0000:00:14.3: 0x00000001 | uCode revision type [ 6.747831] iwlwifi 0000:00:14.3: 0x00000048 | uCode version major [ 6.747834] iwlwifi 0000:00:14.3: 0xDAA05125 | uCode version minor [ 6.747838] iwlwifi 0000:00:14.3: 0x00000351 | hw version [ 6.747841] iwlwifi 0000:00:14.3: 0x18C89001 | board version [ 6.747844] iwlwifi 0000:00:14.3: 0x8002FC12 | hcmd [ 6.747847] iwlwifi 0000:00:14.3: 0x00020000 | isr0 [ 6.747851] iwlwifi 0000:00:14.3: 0x00000000 | isr1 [ 6.747854] iwlwifi 0000:00:14.3: 0x08F00002 | isr2 [ 6.747857] iwlwifi 0000:00:14.3: 0x00C0000C | isr3 [ 6.747860] iwlwifi 0000:00:14.3: 0x00000000 | isr4 [ 6.747863] iwlwifi 0000:00:14.3: 0x00000000 | last cmd Id [ 6.747866] iwlwifi 0000:00:14.3: 0x004CADF8 | wait_event [ 6.747870] iwlwifi 0000:00:14.3: 0x00000000 | l2p_control [ 6.747873] iwlwifi 0000:00:14.3: 0x00000000 | l2p_duration [ 6.747876] iwlwifi 0000:00:14.3: 0x00000000 | l2p_mhvalid [ 6.747879] iwlwifi 0000:00:14.3: 0x00000000 | l2p_addr_match [ 6.747882] iwlwifi 0000:00:14.3: 0x0000000B | lmpm_pmg_sel [ 6.747885] iwlwifi 0000:00:14.3: 0x00000000 | timestamp [ 6.747888] iwlwifi 0000:00:14.3: 0x00000020 | flow_handler [ 6.747931] iwlwifi 0000:00:14.3: Start IWL Error Log Dump: [ 6.747934] iwlwifi 0000:00:14.3: Transport status: 0x0000004A, valid: 7 [ 6.747938] iwlwifi 0000:00:14.3: 0x20000066 | NMI_INTERRUPT_HOST [ 6.747942] iwlwifi 0000:00:14.3: 0x00000000 | umac branchlink1 [ 6.747945] iwlwifi 0000:00:14.3: 0x80455E9C | umac branchlink2 [ 6.747948] iwlwifi 0000:00:14.3: 0x8047257E | umac interruptlink1 [ 6.747952] iwlwifi 0000:00:14.3: 0xC0081DC8 | umac interruptlink2 [ 6.747955] iwlwifi 0000:00:14.3: 0x01000000 | umac data1 [ 6.747958] iwlwifi 0000:00:14.3: 0xC0081DC8 | umac data2 [ 6.747961] iwlwifi 0000:00:14.3: 0x00000000 | umac data3 [ 6.747964] iwlwifi 0000:00:14.3: 0x00000048 | umac major [ 6.747968] iwlwifi 0000:00:14.3: 0xDAA05125 | umac minor [ 6.747971] iwlwifi 0000:00:14.3: 0x00110257 | frame pointer [ 6.747974] iwlwifi 0000:00:14.3: 0xC0887EFC | stack pointer [ 6.747977] iwlwifi 0000:00:14.3: 0x00010C00 | last host cmd [ 6.747980] iwlwifi 0000:00:14.3: 0x00000004 | isr status reg [ 6.748004] iwlwifi 0000:00:14.3: IML/ROM dump: [ 6.748007] iwlwifi 0000:00:14.3: 0x00000003 | IML/ROM error/state [ 6.748031] iwlwifi 0000:00:14.3: 0x00005646 | IML/ROM data1 [ 6.748059] iwlwifi 0000:00:14.3: 0x00000080 | IML/ROM WFPM_AUTH_KEY_0 [ 6.748082] iwlwifi 0000:00:14.3: Fseq Registers: [ 6.748102] iwlwifi 0000:00:14.3: 0x60000000 | FSEQ_ERROR_CODE [ 6.748123] iwlwifi 0000:00:14.3: 0x80290033 | FSEQ_TOP_INIT_VERSION [ 6.748144] iwlwifi 0000:00:14.3: 0x00090006 | FSEQ_CNVIO_INIT_VERSION [ 6.748165] iwlwifi 0000:00:14.3: 0x0000A482 | FSEQ_OTP_VERSION [ 6.748186] iwlwifi 0000:00:14.3: 0x00000003 | FSEQ_TOP_CONTENT_VERSION [ 6.748207] iwlwifi 0000:00:14.3: 0x4552414E | FSEQ_ALIVE_TOKEN [ 6.748228] iwlwifi 0000:00:14.3: 0x20000302 | FSEQ_CNVI_ID [ 6.748250] iwlwifi 0000:00:14.3: 0x00000501 | FSEQ_CNVR_ID [ 6.748271] iwlwifi 0000:00:14.3: 0x20000302 | CNVI_AUX_MISC_CHIP [ 6.748294] iwlwifi 0000:00:14.3: 0x00000501 | CNVR_AUX_MISC_CHIP [ 6.748316] iwlwifi 0000:00:14.3: 0x05B0905B | CNVR_SCU_SD_REGS_SD_REG_DIG_DCDC_VTRIM [ 6.748338] iwlwifi 0000:00:14.3: 0x0000025B | CNVR_SCU_SD_REGS_SD_REG_ACTIVE_VDIG_MIRROR [ 7.093147] iwlwifi 0000:00:14.3: Failed to run INIT ucode: -110 [ 7.105821] iwlwifi 0000:00:14.3: retry init count 2
I really hope one of you will help me. Thank you so much for your time!
