I installed Ubuntu 20.04 on my Huawei Matebook 14 (Intel Core ultra 5 with arc graphics) because of my project team membership. However, after installing Ubuntu, the Wi-Fi was not working. It is not a connection problem; I simply do not have a button for Wi-Fi on the screen. How can I solve this problem? I have to use the 20.04 version of Ubuntu.
Asked
Active
Viewed 101 times
Open 'Additional Drivers' and you should see the driver listed. you will see 'do not use the device' AND 'Using (your driver type here)'. Click on 'Using (your driver type here)' and click 'Apply Changes'. If it works, install all updates before restarting your PC. If that doesn't fix it you'll need an ethernet cable that connects directly to the router. At that point you can fix any wifi related issues and install all updates. Good luck.
gardengnome
- 26
