This may be more than one issue; upon starting a YouTube video or a video file in VLC, the audio is silent for about 2 seconds before playing. Same delay problem happens when playing audio in Spotify and other programs.
Then, during video playback, it will play normally for 5 to 10 minutes, sometimes longer, but inevitably the audio will drop out for about a second, and repeatedly drop out a couple times, before resuming normally.
I've read a solution that suggest changing the pulseaudio config file from
## Automatically suspend sinks/sources that become idle for too long
# load-module module-suspend-on-idle
To
However, I cannot seem to find these lines in the pulseaudio config file
I have no other issues with video playback. It is present regardless of whether the display refresh rate is 60hz or 59.94hz. I'm struggling to diagnose this issue.
Output of aplay -l:
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1150 Analog [ALC1150 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1150 Digital [ALC1150 Digital]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 3: HDMI 0 [AV Receiver]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: HDMI [HDA ATI HDMI], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
pactl list outputs:
Command 'pactl' not found, but can be installed with:
sudo apt install pulseaudio-utils
pulseaudio -k outputs:
Command 'pulseaudio' not found, but can be installed with:
alsainfo.sh --no-upload outputs:
alsa-info.sh: command not found
lspci -nn | grep '[04[80][13]]' outputs:
00:01.0 PCI bridge [0604]: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07)
00:14.0 USB controller [0c03]: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller [8086:a12f] (rev 31)
00:1f.0 ISA bridge [0601]: Intel Corporation Z170 Chipset LPC/eSPI Controller [8086:a145] (rev 31)
00:1f.3 Audio device [0403]: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller [8086:a170] (rev 31)
03:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Navi 10 HDMI Audio [1002:ab38]
05:00.0 FireWire (IEEE 1394) [0c00]: VIA Technologies, Inc. VT6315 Series Firewire Controller [1106:3403] (rev 01)
0a:00.0 USB controller [0c03]: Intel Corporation DSL6540 USB 3.1 Controller [Alpine Ridge] [8086:15b6]
