In Rhythmbox's Preferences, you can change the "Preferred Format" for Music to MPEG Layer 3 Audio, Ogg Vorbis, FLAC, or MPEG 4 Audio. However, despite there being a Settings button, it does not become enabled for any of these choices. (I have installed all of the gstreamer plugins, but this has made no difference.) So how can you change the "Preferred Format", for example to change the bit rate or the quality setting?
The following demonstrates how to modify the settings for the preferred format "Ogg Vorbis":
Create a GstVorbisEnc.prs preset file:
$ sudo gedit /usr/share/gstreamer-0.10/presets/GstVorbisEnc.prs
[_presets_]
element-name=GstVorbisEnc
version=0.10.36
[Default]
name=vorbisenc
bitrate=-1
quality=0.6
managed=false
The [Default] section contains the settings for the "Default" preset. The example I have given above is for 0.6 quality (~192kbps) VBR encoding. The default is 0.3 (~112kbps). Quality can be set from -0.1 to 1.0. There is further information on these settings at http://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-base-plugins/html/gst-plugins-base-plugins-vorbisenc.html
Now add the line "preset = Default" to the [streamprofile-oggvorbis-1] section in rhythmbox.gep:
$ sudo gedit /usr/share/rhythmbox/rhythmbox.gep
parent = oggvorbis
type = audio
format = audio/x-vorbis
presence = 1
preset = Default
And this demonstrates how to modify the settings for the preferred format "MPEG Layer 3 Audio":
Create a GstLameMP3Enc.prs preset file:
$ sudo gedit /usr/share/gstreamer-0.10/presets/GstLameMP3Enc.prs
[_presets_]
element-name=GstLameMP3Enc
version=0.10.36
[Default]
name=lamemp3enc
target=bitrate
bitrate=128
cbr=true
encoding-engine-quality=high
mono=false
The [Default] section contains the settings for the "high" preset. The settings above are for 128kbps stereo CBR encoding. There is further information about the possible values at http://gstreamer.freedesktop.org/data/doc/gstreamer/head/gst-plugins-ugly-plugins/html/gst-plugins-ugly-plugins-lamemp3enc.html
Add the line "preset = Default" to the [streamprofile-mp3-1] section in rhythmbox.gep:
$ sudo edit /usr/share/rhythmbox/rhythmbox.gep
parent = mp3
type = audio
format = audio/mpeg, mpegversion=1, layer=3
presence = 1
preset = Default
Thanks to preiaen for providing the link that helped me find a solution:
Bug #945987 “No Settings are available in “Preferred format” https://bugs.launchpad.net/ubuntu/+source/rhythmbox/+bug/945987
This led to the following pages where I found further information:
[SOLVED] How to edit CDRip settings in Rhythmbox - Ubuntu Forums http://ubuntuforums.org/showthread.php?t=1965432
Linux Format forums :: View topic - Ubuntu 12.04 LTS Released http://www.linuxformat.com/forums/viewtopic.php?p=106176
- 1,364
In Rhythmbox go to Edit --> Preferences--> Music --> Preferred format --> then simply select your preferred format from the drop down menu.
Another method would be to change it via pipeline to something like:
audio/x-raw-int,rate=44100,channels=2 ! lame name=enc mode=0 quality=0 bitrate=192 ! id3v2mux
If you need to store tracks in the MP3 format (for example, if your portable music player only supports MP3 and not Ogg Vorbis), you will need to create a new profile. To do this, click on Edit Profiles, click New, and name the profile MP3.
Select the MP3 profile and click the Edit button. Set GStreamer Pipeline to audio/x-raw-int,rate=44100,channels=2 ! lame name=enc ! id3mux
Set the File Extension to mp3, and select the Active check box. You will have to restart Sound Juicer to see the new audio profile.
This profile uses the LAME MP3 encoder, so you will need to have the GStreamer LAME plugin installed.
Source: linuxquestions.org
